problems saving changes in tuner pro
After I make a change to the program ( doesn't matter if
in constants or tables ) I click save on the box that I made
the change in , no problems . Then I try and save the the
Bin by clicking on File-Save Bin or Save Bin As and I get
a message that says this program has performed an illegal
operation and will be shut down . i have tried in both tuner pro
and tuner pro rt . this is something new as i have been using
this for a couple months now without any problems .
any ideas how to fix it ?
mike
mike
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Something screwy in your XDF definition possibly.
Try a different one to see if the problem repeats.
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Almost definitely a checksum problem. Make sure the checksum is set up correctly (the checksum lives int he XDF header).
someone972
08-30-2015 12:52 AM
LT1Formula
08-20-2015 09:36 PM
