Cylinder select netres values?
Hey everyone,
Question that I couldn't find the answer to... I need to turn some v6 memcals into v8 memcals. Without having to go through the gory details, just trust me when I say it's easier for me. Basically my problem was, I need a V8 memcal with a 3.1 knock sensor board.
But anyways, on the 1227730, what resistor(s)/pins of the netres correspond to the "hardware" cylinder select? I have both v6 and v8 memcals to double check...
1 Post
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
Re: Cylinder select netres values?
https://www.thirdgen.org/techbb2/sho...res+cyl+select
Last post, somebody might have this document... I'll PM him as well.
Engine: Many
Transmission: Quite a few
Hey, I got your PM. The pins I was talking about in those posts weren't for the cylinder select pins. They were an actual resistor value tied to ground to an unused pin on the knock board, which specified what the tuned frequency was for any knock filter board, and the application. Since there aren't any markings on it, I guess the factory gave a resistive ID to them all. I put this document somewhere, I'll have to dig it up, though maybe I didn't and just gave it to anyone who PM'ed me long ago. I figured this out from two or three documents that were on the ftp site for diy-efi.org.
the cylinder select pin, however, is on the memcal, in the two small 'chips' under the knock circuit. I do have this info somewhere, probably from something in diy-efi.org, or I think I recall grumpy posting something about this.
If you rewire the 3.1 memcal, bear in mind that the limp home settings may not work for your application, it will think its a v-8 and the knock will work for whatever you plan to do, but if the prom ever fails, I don't know what the outcome will be.
i started to decipher this stuff awhile back, but the res network doesn't make sense in alot of cases, and trying to run the equations for the network seemed crazy, so being the lazy guy I am, I left it at that.
sorry I'm not much help at this point, I'll dig around and see what I can find, but it might take a couple days.
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
There was a note by Rbob in this thread.
https://www.thirdgen.org/techbb2/sho...ghlight=select
May be only for TBI but thought it might be useful to you.
Jp
Jp
Car: 89 C2500
Engine: ZZ838, MPFI, Whipple, & 7749 ECU
Axle/Gears: 4.10
When I was working with the 1227749 and TBI a while back, I found CAL56 (memcal pin 56) was used for cylinder select. I believe I determined this by looking at the ECM schematics on Ludis' site. He's got a ton of valuable info there!
Oh, the 1227749 is very similar to a 1227730. Currently, I'm using a '730 AUJP V8 memcal on my '749 running MPFI.
Also found this in my junk, Authors name is on it.
I never confirmed how different it was to a V8.
Please post what you find.
THX
THX
Maybe I'm missing something here.. There are 2 chips under the knock filter board. I assumed they were both "netres"... There's a 14pin and a 16pin. Is the 16 pin the one that has to do with the cylinder select, and the 14 pin the "limp home mode"?
btw- if indeed it is CAL56, then that simple 7.5k resistor is all that needs to be changed. In the v6 memcal I have here, that is a 15k resistor. I can check tomorrow on the value in the V8 memcal, and do some experimentation with the value if it too shows 7.5k....
Car: 89 C2500
Axle/Gears: 4.10
CAL56 would be on the 16 pin chip. Check out the memcal doc found here ftp.diy-efi.org/uploads/memcal.pdf
The netres in that document is from a twin turbo 3.6 liter V6.
Car: 89 C2500
Axle/Gears: 4.10
thanks, I have that document and the 749(?) schematic, but the 749 schematic seems largely incomplete. It doesn't show where any of the memcal pins lead to, aside from a select few like the knock sensor input/output and power pins.
Wow, I had no idea! Thanks!!
measurements on the v6 memcal confirm what is shown in the memcal.pdf document, 15k to Vnet, and 7.5k to ground.
1/3 voltage divider = v6... I'm guessing maybe 1/4 = v8? bah... I'd better pull the v8 memcal out of my car, because this will be bugging me all night.
ok, V8 memcal still shows the 7.5k resistor to ground, however, the 15k resistor to Vnet is now nonexistant.
So, turning a v6 into a v8 memcal seems simple, just cut the CAL56 and put a 7.5k resistor to CAL53, or on the 16 pin chip itself, put a 7.5k resistor from pin 3 to pin 13. *edit: err, pin 13 no longer has any connection to anything because you physically removed it. I meant a 7.5k resistor from pin 3 to the pin socket on the memcal where pin 13 used to be.
Thanks everyone, couldn't have done it without ya! I'll check it to confirm that I get no error codes later...
You don't go to the yards enough.
I have those laying around.
I let the 1 yr old entertain himself with one.
Pending your results I may need to take it back.
Figuring this out has been on my todo list for a while.
Car: 1969 Z28
Engine: 406 TPI
Transmission: Tremec TKO 600
Axle/Gears: 3.31
ryan.h,
Very interesting subjet. Have you had any success in testing out this idea? I'd like to be able to convert V6 memcals for use in my V8 project and all the EFI community would benefit from "cheaper more plentiful" memcals.
VR,
DZcode
VR,
DZcode
Car: 89 C2500
Axle/Gears: 4.10
Car: 89 C2500
Axle/Gears: 4.10
I did this modification today to a '749 BBZB memcal. Instead of using ground at CAL53, I used CAL62 which is also a ground. Works out great!
1 Post
Engine: 3xx ci tubo
Those surface mount resistors & capacitors are going to be hard to change to get the knock sensor filter to work properly. Laquer thinner/Acetone works well for removing the conformal coating.
Car: 89 C2500
Axle/Gears: 4.10
I couldn't tell any difference between the two when testing them in the vehicle. I test with a BIN that had enough timing in low RPM & high load areas to induce inaudible knock.
Anyway, I've actually removed the ESC filter board and have wired in an LT4 ESC module. This is working much better for my setup. The roller rocker valvetrain I'm running is quite noisy and I was having issues with false knock. I tried the commonly posted resistor network fix...but that really didn't help. I've been running the LT4 ESC module on the AUJP memcal for about a month now. I just moved it to the BBZB V8-adapted memcal yesterday. Here's how I installed it on the AUJP memcal (oh...can't use the blue cover any more )
1 Post
Engine: 3xx ci tubo
I never measured Rs & Cs on a 4.3 memcal KS module. The bore volume theory makes sense.
I like the LT4/AUJP memcal. I looked into the LT4 & LT1 knock modules a while ago. I seem to remember something being up with the fact that some LT1 knock modules are designed for 2 knock sensors and some are designed for 1 knock sensor. I can't seem to remember what the LT4 knock module was designed for. I thought the LT4 was designed for 2 knock sensors. Could be wrong though. Didn't the Corvette & Caprice get two knock sensors and the F-body got one.
It always seemed odd to me that F-body LT1 users (one knock sensor) would throw in a LT4 knock module (two knock sensors). Many claim that the LT4 detects "true knock" due to a better design.......but it is really just because of the resistance change. I wonder if the LT4 is better by design for detecting "true knock".
Car: 89 C2500
Axle/Gears: 4.10
I tested it out on my ECM bench before putting in the the vehicle. It was difficult to tell the difference in sensitivity on the bench, but I see a big difference in the vehicle. Now...am I just detecting "true" knock, OR am I filtering out some true knock, that's the $100 question!
1 Post
Engine: 3xx ci tubo
According to the AC Delco database, the 96 LT4 Vette used one knock sensor.
Knock is funny thing. I don't think you can ever really know, but by the sounds of it you have an ideal knock sense mechanism with currently available hardware.
I have specs on several knock sensors if anybody's interested...
Part #........Fcenter Hz.........Bandwidth Hz......Magnitude V
KS2..........6,306 +/- 370.....130 +/- 129.........1.20 +/- 1.00 (5.0TBI)
KS3..........6,346 +/- 276.....132 +/- 129..........0.37 +/- .25 (5.0TPI and 3.1)
I'm just a little confused....
Can pin 12 be cut and just leave the 7.5 resistor just like it is installed between pin 3 and 13 inside the chip?
did you cut the pin on cal56? If you did, where is the resistor installed...on the chip side of the cut or the out side of the cut?
Does that make sense? I just don't want to screw up...lol
1 Post
Engine: 3xx ci tubo
kik_start,
What RBob and jwscab said is correct. You want to connect pin 13 (cyl select) to pin 10 (ground). That should remove the code 41 error and fire the injectors properly.
You need to know how to count the pins on the chip to find pins 13 and 10.
The picture in the earlier posts shows where the pins 13 and 10 are located.
I did take a picture for you of the memcal pins, but I do not have a means of posting them today.
Engine: Many
good, glad it worked out.
just remember, the knock circuit probably won't work. It might work a little bit under extreme knock, so just be cautious.
if the prom falls out or get's flaky, or otherwise puts the ecm into limp home mode, the engine won't run properly, so if see that, shut it down asap and fix it, don't try limping it home.
Ok I know how to count the pins on the chip correctly but I need to make sure I get this correct.
So I cut the pin 56 from the chip which is pin 13 directly on the chip (netres) Now I do I leave the pin not connected to anything off the chip and runa jumper from the socket on the board to a ground or am I suppose to run the little leg (pin) from the chip and ground it?
Example on the left i didnt cut the pin just ran a jumper wire. Ex on right I cut the little prong Pin 13 on the chip and ran a jumper from where it plugs in the board to pin 10 which is ground. Which one is correct?
Uploaded with ImageShack.us
#42
1 Post
Engine: 3xx ci tubo
You have pins 10 and 14 connected in the picture on the right. That is wrong.
#43
Engine: Many
you don't have to cut any pins.
just jumper pins 10 and 13, and you are done. so your left picture is perfectly fine as is.
#44
Ok thank you!!!! Sorry I was tired when I made the picture. The one on the right is suppose to be the same as the left just with pin 13 cut. Sorry.
Ok Thanks for all your help guys couldnt have done it without you!
