TunerPro v4.12 Released! Many new features...
#52
Car: 1981 Buick Century Wagon
Engine: 87 GN engine
Transmission: 2004R
sorry magnus, os is winxp, build is the latest, d/led it a few days ago, 7 or 8 days. Using the usb autoprom.
#53
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
#54
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Is anyone else having any issues on startup where the ALDL dash either doesn't fully paint, or comes up totally gray. Have to increase it's height to be able to view the fields. And it still flickers on and off while resizing - have to stop the growing part while everything is visible or you have to do it until it does.
This is on a Dell Latitude D600 laptop using the built in screen at a 1400x1050 resolution and using 32 bit color settings. I'm running XP Profession version 2002 SP2, 1.4GHz processor, 512MB memory.
#55
and a bunch of new features (much better logging, better connection routines for the more complex ECMs, histograms, etc).
Adrian
#56
Car: 91 Red Sled
#58
I'll try a lower resolution this evening, but that is "the standard resolution" on this laptop (which is a year old). It does not cause a problem for TunerCat or Datamaster.
Hadn't thought to try a lower resolution to see if that made a difference....
#59
Transmission: T5WC
Originally posted by Adrian
Maybe support for big Bins as well??
Adrian
Adrian
#60
Transmission: T5WC
If it is the issue, the lower resolution will not help unfortunately.
Do the graphs show up correctly?
#61
I'll have to check tonight. It works fine with the laptop in the docking station and displaying on my 19" Dell Trinitron monitor, it's only the laptop screen that sees the problem. I'll get back to ya. And I am running the latest TP-RT version as of the time I checked yesterday morning.
#64
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
http://www.moates.net/fileman/index....es/2%29%20Ford
Mainly just EEC-IV for now. Starter binaries are included there.
#65
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, LT1
Transmission: TKX, 4L60E
Axle/Gears: 3.42, 3.23
-- Joe
#66
Car: 91 Red Sled
#67
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
