Map sensor ID
1 Post
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Map sensor ID
Can someone ID this map sensor for me
I cant trace it to any known good part number
It cam from a bastardized 86 Sunbird that was no longer turbo and rigged to high heaven I grabbed it for an either or scenario, but it had a boost guage and something had to make that read right?
Anyhow the number is 012 6114 and it has the GM symbol on it and 466 written on top of the case.
I think its the 1 bar one, hoping im wrong
later
Jeremy
later
Jeremy
1 Post
Engine: 3xx ci tubo
Transmission: 4L60E & 4L80E
try www.tomco-inc.com
I found more info there about part numbers than any other place. Check out the MAP sensor PDF. It lists the cross references and vehicle usage.
J
J
1 Post
lol
Well it actually came out of a 84 might have been an 86 sunbird formally turbo car.
Was gutted and rigged bad including no longer boosted as well.
Notived the dash guage read to 15psi and thought hey I should grab it while I'm here(map sensor)
So I lucked out
thanks for that Tomco link, I never had that one before.
Now if only the memcal I snagged had been for a 90 seville instead of a 91 I would have had a good trip :-)
later
Jeremy
So I lucked out
later
Jeremy
efiguy
09-27-2015 01:30 PM
