'730 $88 V6 Vats?
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
'730 $88 V6 Vats?
I loaded 730_ATTA.ecu under TunerPro - is 'User Option word 6B5 - Bit 3 - VATS' the bit to enable.disable VATS under the AZTY bin?
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: check
Engine: check
Transmission: check
Yep, looks good to me. Please note that AZTY is an automatic transmission bin (latest and greatest). The bin BAWX is the latest and greatest stick tranny bin. . .
Being that AZTY is FED only, and BAWX is FED and CALI, a mix of the two may be the best bet for the SunShine state.
RBob.
RBob.
Sounds good... just need to bypass the starter enable then, and all's good
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
TFS355S10
50
07-09-2013 08:56 PM
