winaldl trouble please help
Car: 91 camaro 305 tbi
Engine: 305 tbi l03
okay i have everything set to default except the ecm im using and i cant get it to log more than three things....i have an 8746 ecm and a homeade cable. the light at the top flashes off and on red and changes numbers between 1 and 2 in the box. i can log random data in MW2 colum and some points a little less often (not constant like the other one) in PromIDA and PromIDB colums. any idea what the problem could be i will be going no where quick w/ all this stuff i got for tunning if i cant even datalog. thanks
John
Spanky00185@yahoo.com
John
Engine: 305 tbi l03
do i need the 10k ohm resistor between a and b on the diagnostic link?? i was under the impression i didnt for my ecm cause it only sent data from one port? thanks
Car: 1991 Camaro RS
Engine: 355 Vortec TBI
I have a 91 rs originally with the L03. I did not have to use the 10k resistor across a and b to get my data stream to transfer. What are you using to datalog (winaldl)?
I actually had a problem with datalogging earlier this year. I would only get good reads every third pass or so. I found dust and a dog hair (can't get away from the stuff) caught in the EPROM socket. I cleaned it up and cleared up the data stream. Solid reads since. Now I always put the cover back on the ECM.
You may want to double check everything is wired correctly and none of your contacts in your cable are touching one another. Also make sure everything in your ecm is tight and clean.
Engine: 305 tbi l03
yeah im using winaldl....and as far as the dust or bad connections no dust cover stays on and connections should be good due to the fact the car runs decent for the most part. i read u have to close and reopen the winaldl after making changes to the baud rate im gonna try and change that and see if that works if not i dunno what the problem is. thanks
John
John
i purchased a cable with customefis.com and i think it was $40. the serial to usb was purchased afterwards(Radio Shack) as i changed laptop with XP. only issue was comp ports but that was solved in 24 hours. i connect to winALDL while car is running. i actually put in toggle switch and ALDL port connection stays in place. are you confident the cable was constructed correctly?
Engine: 305 tbi l03
yeah the cable is contructed right all it is is two wires to the aldl port, three to the serial connector, a transistor and a couple of resistors...im bout to go back out and change those settings and see what happens.
Car: 91 RS
I'm certainly not an expert but being a newbie to winaldl I can relate.
The box at the top needs to flash green. I remember it flashing red once and the tables not working.
The cable under the dash was loose and did not have a good connection. After inserting it fully it has not happened again.
It's not getting full data.
Engine: 305 tbi l03
do u happen to have a part number on those male connectors cause i may not be getting a good connection the way im tryin to do this cause i remove the neg. pin from aldl and its still populating those two tables??
Car: 1983 G20 Chevy
Transmission: 4L60
I found a connector for a Genisys OTC scan tool on ebay, bought it for like $5.00, built it into my cable, and I have a good solid connection to my ALDL now.
