'89 Tpi Ragtop Datamaster File
Hey Gang...
I'm new to this area.. Just bought a nice '89 TPI 5-speed Ragtop IROC. I am very interested in this section of the board and have started reading through what you guys are up to.. I logged a 5 minute drive with data master and was wondering if one of you would be kind enough to take a look at it and tell me how far outa whack this car is running...??
The car seems to run a little rich... It throws no error codes and might have an after market chip in it.
Thanks in advance for any help you can provide!
SeanDownload Datamaster file here!
Car: Z28
I have no idea. I've never used Datamaster - but most all the aldl data loggers have some way to post plain text, or even an excel spreadsheet.
anyone else used datamaster and can comment?
Thanks!
Will do.. I think I was playing with that function last night but wasn't quite sure what I was dealing with. I selected a few items on the list and it seemed to output only the reading that was taken at that very point in the timeline. If this is the case, maybe I will try to select the readings at idle and then also one from WOT..
Will upload tonight when I get home.
Thanks for the help!
Sean
Sean
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Do you know if you're running speed density, or are you using a MAF? I looked at the DM file, but I only have the speed density setup in DM, so that's probably why I was seeing some pretty strange things in your log file.....
Ok,
Here is the Datamaster file as exported to an excel format... There is alot of information there... If you guys need only specific items, I can pare it down.
Thanks!! I really appreciate the help
Sean
File LINK in Excel format
Sean
Car: 1986 vette/91 RS Vert
Engine: zz4 l98/Tbi 305
Transmission: 700r4/ 5 speed
I looked at the datamaster file other than the rich condition the only thing I noticed was that its adding knock retard in the mid to high teens when you go to wot. In other words its removing spark advanced when you give it the gas pedal.
Watch the knock counts and knock retard when you play it back.
I don't claim to be an expert but if it is rich then no. The timing maybe set too high.
Check to see where the base timing is set.
hmmmm,
Just looked for the brown EST wire on the firewall and it is not there... I want to reset the timing.... Is it in a different location for 1989?? My '87 has it in the usual place.
Sean
Sean
Thanks for writing back so quickly... It is not there... My 1987 TPI has it right where it should be.. This car (89) does not....
hmmm
any ideas??
hmmm
any ideas??
Change in direction!
It got too dark to mess with the timing so I pulled the ECM from under the dash and looked at the EPROM....
I think this is the culprit.. Here are the numbers on the PROM in my car now:
16133420
APYS 3509
I thought ANXY was the correct broadcast code for my car's PROM ('89 TPI Manual)????
The code on the outside of the ECM is 1227165 which I believe to be the correct ECM for the car.
It appears this car has the wrong chip in it. If I am on the right track please let me know.
Sean
16133420
APYS 3509
Sean
Car: '89 Trans Am GTA
Engine: TPI350
Axle/Gears: BW 3.27s
I'm not sure what ANXY is for... Using this site I was able to put in APYS for the broadcast code, and it shows that chip is for an '89 5.0 with a manual. Not saying that the site is right, but I dunno why else it would be there... Unfortunately, I'm just now learning to use my Autoprom (just trying to get used to using it connected to my computer and software) so I can't make any suggestions for your condition. Good luck though =)
Thanks you guys..
Luke4907 - thanks for the link to that site.
Slow89 -I will reset the timing in the morning.
Thanks for the assistance. I hope to be burning my own PROMs in the near future.
Regards,
Sean
Regards,
Sean
Ok,
I the timing was off. I did reset it and the car ran better but still a little off. I changed out the chip just for fun since I have a brand new one for the car and now it doesn't seem to be running rich anymore. I will do some more datalogging and see how different things look now.
Regards,
Sean
Regards,
Sean
Sanjay
08-12-2015 04:41 PM
