Need 16168625 pinout ASAP..
Car: Take your pick. Probably a '72 Cheyenne/20 or '91 Maxima
Engine: Truck has a 350 W/454 TBI, 350 Injectors, 7747/G2/Atmel
Transmission: TH350...Aint dat a bitch
Hey guys, was reading the "TBI Guys: Time to update!" thread and decided to get myself a 16168625 ECM...I've already torn apart the memcal and soldered in a ZIF for my Ostrich, however I now need to make an adapter between the 8625 ECM and the harness I have for the 7747 ECM & TBI setup in my truck. I already have a dead 1227747 ECM and the pigtails for the 8625, so I'm planning on soldering together a harness that adapts the 8625 into a 7747 connector (in the event I ever want to swap back to a 7747).
I don't need a pin-pin comparison as I can figure that out on my own and I got a 7747 ECM pinout from chevythunder.com...but I really need the 8625 pinout. Thanks!
Oh btw if you can't attach it here...send it to kris (at) speedyoldtruck (dot) com, thanks.
Originally posted by RBob
Double check the 'time to upgrade' thread. I am certain that there is a to-from list posted. As an image file.
RBob.
RBob.
Car: check
Engine: check
Transmission: check
Ahh, Dominic threw a curve ball, but the bat finally connected. Check this thread:
https://www.thirdgen.org/techbb2/sho...hreadid=272975
RBob.
RBob.
