Aldl Cable? Is This A Good One?
Car: 74 buick apollo
Engine: twin turbo 383
Transmission: TCI comp th400
hi i found an aldl cable that looks pretty good for fairly chep dose any know anything about it?
http://www.mastach.com/index.php?mod..._hardware&l=en
1 Post
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Mine works like a charm.
Might want to shop around a little and see if he is still doing ebay auctions. His prices seemed to have gone up alot since I have dealt with him.
later
Jeremy
later
Jeremy
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Sure does! That's what I've been using the past year or so....
Car: 91' Pontiac Firebird
Engine: 388 ci Small block CHEVY (4.060x3.75), Dart Iron Eagle Platinum 200cc, Performer intake, 454 TBI, Long Tubes, True Dual 3" GPs
Transmission: 700R4, B&M, Governer Recal, 20,000 GVW cooler
Winford Engineering sells the connector and hood for cents and all you need is to goto radio shack and spend $2 on a transistor and 10 k ohm resistors. Than a few feet of wire which I am sure you could find around your house.
Dont put in R4 (carbed cars) or R3 (well, you may need it if it dont work)
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
I bought one from Mastach that I use now with no problems and built one from the diagram above but couldn't get the dumb thing to work on my LG4.
But the nice little note about the R4 resistor might be the key
Thanks for the refresher
Car: 1991
You can get a really solid one for less at:
www.aldlcable.com
www.aldlcable.com
9192camaro
16
02-03-2019 12:21 AM
db057
08-11-2015 10:11 PM
