knock during tip-in.
Whery often I get a knock count during tip-in, and downshift ( manual car ). It takes out 0.1-1 degree of timing. I cant tune this out, is it just something you have to live with?
thanks
thanks
hmm does everyone manage to get zero knock counts? Even on heavy modified cars?
I tried many things to get my knock counts to zero under all conditions. But during downshift and sometimes during tip-in, I can see whery short spark retards and I cant manage to tune those outs.
Regards
Devil....
Regards
Devil....
1 Post
Car: An Ol Buick
Engine: Vsick
Re: knock during tip-in.
Add a lil fuel or back a lil timing out/ look at your burst knosk settings.
Re: Re: knock during tip-in.
Originally posted by Grumpy
While 1d doesn't seem to be much, it still might be an indicator of tip-in preignition, and can be life threatening to the engine.
What really puzzels me is the downshift bit. When going from low rpm to high rpm fast. I cant se how to tune out the knocks from there. Cause BLMS is good at both rpm. And when I keep the car stabel at those rpms I got no knocks.
Its just at that exact moment as I engage the clutch going from a high to a low gear. There I got a knockcount.
cheers
devil..
Car: check
Engine: check
Transmission: check
Re: Re: Re: knock during tip-in.
cheers
devil..
cheers
devil..
At this point I'd recommend that you pull the plugs out and check them for signs of detonation. If no signs then ignore the counts, if signs then need to work on it.
RBob.
RedLeader289
05-28-2019 01:47 PM
bigjay89gta
10-15-2015 08:04 AM
efiguy
09-27-2015 01:30 PM
