MasTach cable, says no signal from ECM???
What gives, I followed the hookup diagram exactly how they illustrated. The diagnosic says the cable is working properly, but it fails to get a reading from the ecm. Anyone experience something similar with the mastach cable? This is kind of pissing me off. I would really like to see what is going on in there
Will
Will
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
What software are you running?
Check the comm port settings, that's usually the culprit.
If your using a USB to serial adapter there could be problems with that as well.
Lot of people having issues with them.
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Do you have 10K between pins A & B of your ALDL connector or cable? Your '89 needs this.
wigmobile
09-17-2015 03:38 PM
