Have questions for DataMaster/VEMaster/Tunercat
1 Post
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Trying to make all this work properly and couldnt find a how to per se here searching.
I know to open VEMaster and then pick my rpm ranges and BLM(128), but how do I go from that to the tables and inputting them into TunerCat?
I think I'm missing something dumb, so could someone shed some lite for me?
thanks
Jeremy
91 383 SD if anyone cares :-)
thanks
Jeremy
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
VEMaster directly alters the BIN file... You tell it where to find a datamaster log, tell it where to find a BIN file, then set your maximum RPM and desired BLM values and start it... It computes and _executes_ the changes to the bin file... So basically, when I run it, I make a copy of my last bin file, then run VEMaster with a log file on the copy.. Then go in with TunerCat and explore the changes it made (and make adjustments as necessary)..
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
Don't forget
After the changes have been made, you must open the bin in TC or TP to recalculate the checksum. The VE table changes are done but no checksum.
1 Post
Ahhhhhhhhhhh I see said the blind man lol
Thanks a million , the part I didnt realize/find was it dorectly changes the .bin itself. Now it all makes sense.
I'm still in awe of having all my tuning stuff on one laptop, I like doing things the hard way :-)
This will be sweet and easy.
later
Jeremy
later
Jeremy
1 Post
Wow
If only I wasnt stupid and updated my whole setup sooner.
Drove and did all kinds of pulls today, slow, hard, fast, TC locked and unlocked, etc and so forth.
Have most of the VE table sorted out thru 4k rpm.
Gonna try and run it thru emissions today also(IM 240)
Few more miles and I can safely put the LM-1 on and work on the AE and PE stuff and more safely work on the spark table.
later
Jeremy
later
Jeremy
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Jeremy - did you get the e-mail I sent you lasat week about your new setup?
1 Post
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: Don't forget
I see VEMaster asks for a Datamaster log file, but then asks for an ECM file? Will a Tunerpro 8D bin work? or does it have to be a Tunercat Ecm file?
Re: Have questions for DataMaster/VEMaster/Tunercat
If you are using the $8D version of datamaster the log will output what is needed.
VEMaster will prompt you for your starting bin file (with the VE tables that the log was made from)
Then VEMaster will change that bin file to update the VE tables with the error correction from the log file.
I have found it best to keep your starting bin file separate.
Have VEMaster change a renamed copy.
Then after three files have been logged and changed, open your "changed" bins in an editor (TC or TP) and copy each of the three into a spreadsheet and obtain the average change that was made.
Makes for a much more stable table than doing one log and change at a time. that can cause over/undershoot with the corrections and you may go back and forth a couple times.
HTH
HTH
And don't forget to open a corrected file in your editor and resave it prior to running it.
The checksum is not uprdated by VEMaster. The editor will update that upon a file save.
1 Post
Axle/Gears: 3:42
HTH
HTH
If you have the "Mask ID" set to 8D in the bin, you will throw code 51 (bad checksum)
If it is set to "AA" the checksum will be ignored.
