where should O2 threshold be for more overlap?
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
I have been tuning my 6E motor for about 6 months now and am just starting to get close to trouble free operation. One question keeps poping into my head though...
I am running the zz4 cam with 1.6 rr in my little 305 (tpi) and it has certainly changed the behavior quite a bit from the peanut cam I had in there. Now getting a smooth idle is very difficult and I was thinking that with more overlap the O2 threshold rich/lean point should change. the question is which way.
I figure with more overlap at idle, more of the intake charge on average would go by the O2 sensor per pulse from each cylinder so this would lead me to belive I need to lower the O2 constants to get 14.7 in the chamber at ignition.
Sound right?
Sound right?
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
so no one wants to take a shot at this topic?
I thought for sure someone would have changed their O2 cross point to make the computer control to what the engine really needs...
1 Post
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
If u did a you would have found at least one post concerning it in the stickies and there are several more around.
For an example, here is one from the "Tuning FAQ" at the top of the board.
https://www.thirdgen.org/techbb2/sho...ghlight=afs+74
later
Jeremy
later
Jeremy
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Well Jeremy, I have done searches in the past and have read this thread many times including today where I found that you yourself do not seem to understand the answer to my question either.
Someone care to break down and explain the o2 constants to shed some lite on them?
Goofed with them a few times using the romulator b ut never quite figured them out or which would work most for my benefit
thanks
Jeremy
This issue in my head is far from resolved in the existing threads and I for one would like to start additional dialogue.
I have disabled AIR on my rig but I seem to still have trouble getting a smooth idle quality. I also get a good bit of eye watering stink with extended idling.
I of course will "goof with" the O2 threshold and min max values as you have done -- I was only asking if there were more learned opinions out there like trax, that could give more definitive (read quantitative) suggestions...
thanks
Jeremy
FWIW, idle problems may result from either mechanical or control issues.
A brief technical discussion of GM control parameters is found here, with some
additional reference material:
http://www.454ss.com/cgi-bin/2004for...num=1081825382
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
This is one of the papers written a while ago on the 747.
Very good reading and should ansew most if not all of your questions regarding the o2.
http://www.diy-efi.org/gmecm/papers/747fuel.txt
There are several others there worth reading as well.
I of course will "goof with" the O2 threshold and min max values as you have done -- I was only asking if there were more learned opinions out there like trax, that could give more definitive (read quantitative) suggestions... [/B]
ben.
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Yes I have tried that. I have about 25 degrees now but have tried even more with no success curing a slight hunting condition and what feels like intermittent missing.
Car: 82 Z-28
Engine: 383 TPI
Try moving your O2 threshold up.
I have my "Closed loop rich/lean threshold Vs airflow" set to 747mv for 8 grams/sec MAF flow.
I was having a rough idle issue and what felt like an intermittent miss. My WBo2 was showing my AFR at ~15.5-1...
Now it's abt 14.0-1 and seems much happier.
Grim Reaper
30
03-31-2003 03:12 PM
