help with moates ostrich
Car: 86 IROC w/Danko bodykit, 1988 iroc vert, 1989 k1500 pickup 6" lift and 35" tires, 2002 chevy tahoe z71
Engine: 383 stealth ram, 305 tpi, 350 tbi, 5.3l
Transmission: T56, 700r4, 700r4, 4l460
hey guys i just have a quick question. i downloaded a bin file that is similar to my seet up that i am going to run. i purchased a moates ostrich unit off of a guy here on thirdgen my problem is how do i upload the bin file to the ostrich unit. is ther software that i am supose to use with the ostrich unit. my computer doesnt reconize the ostrich unit so i thought that maybe that was the problem. i hope that i am explaining this right. thanks in advance.
You will need a laptop and Tunerpro RT. After installing Tunerpro RT, you will need to connect the laptop to craigs ostrich, plug in the ostrich to the cars computer, open the bin file using the correct ecu file, upload the bin to the ostrich using Tunerpro RT, and then enable emulation. There is a lot of info on marks site and on craig moates site. Check them out and dont forget to donate the $30 for Tunerpro RT. This tuning software is dynamite!
so you need to connect to the laptap to the car first in order to upload the file to the ostrich.
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
First thing you need to do is install the driver for the Ostrich. See Craig's web site for more info. www.moates.net
that might be one of the things that i need to install the driver first. 2nd i need a new memcal now since i messed up one of the pins on it trying to take out the old one. anyone know where i can buy a new memcal. i think that's what the part is called. its where the chip plugs into than that plugs to the ecm.anyone know where i can buy one
Just buy the adaptor from Moates and be done.
~$10 is cheaper than new memcals. I suspect the chip is the only thing you messed up, not something you need with ostrich now if you get adaptor.
yea craig just emailed me and asked why did i pull it out instead of using the adapter.. i didnt know thats why. i am not the brightest crayon in the box. anyway i downloaded the driver program and i still cant get to work. on the bottom of turnerpro it has a red box that says not emuatling and it says next to it hardware not found. any ideas or did i installl the drivers wrong.
UltRoadWarrior9
04-28-2020 10:39 PM
