Datamaster Question
1 Post
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Datamaster Question
Is there a way to connect and just get the aldl data without recording?
I dont need it for recording when I'm emulating..
Was out for about an hr or so with it and always had to "record" to start the process?
Am I missing somethign or is that how it is?
later
Jeremy
later
Jeremy
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
yes,
There's "monitor" button that does just that.
1 Post
Thanks alot JP :-)
Everytime I try and teach myself something new I go from smart to stupid in a flash.
Must have just missed it, no rain today so I will play with it further lol.
thanks
Jeremy
thanks
Jeremy
1 Post
OK,
I give or lost a few brain cells, I went out to the car and also pulled up yesterdays logs inside and I'm still missing this monitor button?
Where is it at? (hope i dont sound to stupid here)
Help says version 3.4 on has monitor. Checked mine and its version 3.4 fresh from tts.
later
Jeremy
later
Jeremy
Should be right there next to start and stop
edit: mine shows 3.4.1 downloaded.
This might be the "beta" version.
The beta has a nicer histogram, haven't had any bugs with it.
Still saving my 20 free logs.
1 Post
Hmm interesting.....
Is this the downloaded free version correct?
Has 20records before u have to register, but you can do it live playbakc for free? logging wise?
I dont have box like you do? What file was it under or not under any at all?
Interesting
I have the reg version and just went and dowloaded the beta also?
Have reverse/forward and start/stop and a fast/slow bar though?
Can u send your original zip file of it to me(via email) maybe it no longer is given freely?
thanks
Jeremy
Interesting
thanks
Jeremy
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Go to FILE, then RECORD, and then you'll see the MONITOR buttom
Yep, you have to be in the actual recording box.
you're looking at the playback controls.
1 Post
Ahhhhhhhhhh I see said the blind man :-)
Now I can recall seeing it the other day when I first tried it lol
Thanks guys, I appreicate the help, I promise I'm okay once I figure something out lol
edit: Wow am I dumb lol I started laughing when I found it, was staring dead at me. Too much something I'm guessing wow.
later
Jeremy
later
Jeremy
1 Post
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
And your other question, if I understood it correctly...yes, playback of previously recorded runs is free.
1 Post
Thanks guys,
I think I have it all fijiguremured out :-) lol
Wasted 4-5 records to do it, but was out using it and TC RT.
Going to try my hands at some VEmaster next lol(scary thought isnt it)
Appreciate it,
Jeremy
Appreciate it,
Jeremy
1 Post
Ok :-)
I have a question to add to the orignal question.
How come no matter what I do I always end up "burning" one of the RECORD sessions?
I go to file I go to record and hit enter, as soon as I do this it uses another record session.
Am I missing something completely idiotic again or have the changed the version somehow?
I found the "record option on" and "autorecord on" but I am unable to uncheck the flag for "record option on" and everytime I try, I just cant monitor but it also uses a "record"
later
Jeremy
later
Jeremy
I believe the count increments each time the "record" dialog is opened.
1 Post
Thats exactly what I am getting JP.
But how is it people are "saving" their record logs then?
I cant make it just "monitor" without also eating another "record".
Down to 9-10 now and counting lol
Different versions or are they doing something different than I am?
edit: How do I "monitor" without using up a recording?
later
Jeremy
later
Jeremy
Car: 68 Camaro
Engine: 5.7 TPI
I don't think you can monitor with out going threw the record box. I think this is there way of getting you to purchase the product. You will use up about 10 axcidentel, then the next 10 gets you hooked on the product wanting you to purchase it. Good stragedy on there behalf. I don't use data master because of usb problems, but I will tell you there is a way to get 20 more sesions as I axcendently stubled across it - believe me it is invloved and I don"t want to say how to do this here for they have a right to make there money, but it is possible since I seen my records go from 13 back up to 20.
