OTC 4000E TPI cable
1 Post
Car: 85Z28 87GTA 91GTA 98SS
Engine: SBC, LS-x
Transmission: T-5, 700-R4, T-56
OTC 4000E TPI cable
I just bought an old ATC 4000E that came with a grey TPI cable. My car is an 87 305 TPI.
From a search I found that sometimes the TPI cable is needed, more times the regular GM OBD I cable is needed.
I am getting eratic readings with the tool. Idle RPM at 6260, voltage at 25, injector pulse width 0 ect.
I suspect I need the regular cable.
Does any body know the pinouts for both cables or if you have the regular cable, list what the pinouts are for both ends?
I think I could cut and splice it to make it work.
The old cable does not appear to be for sale anymore.
Car: 850ci
Engine: 12
Transmission: 6Spd
The Gey one is the one you need for TPI .
as for the black cable thats is for Carb,TBI you can use this too but without high speed data.
Sounds like 4000e need's to be Repaired
I have both the 2000 & 4000 and they will do this.
is your Primary coolant fan coming on at wrong temp too.?
(thats is if you have)
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
I *think* the TPI cable is only needed for the 165 ECM's in TPI applications, not sure about 730 TPI. I can take a look tomorrow at work, as we have a 4000e and a genisys. Pretty much any other 82-95ish application uses the black, standard adapter, even for high speed ALDL. Example, every application that has a 730 that I've scanned (haven't scanned a 730 TPI lately) uses the black cable, along with the 4 cyl TBI 165. I have to use the scan tool on for sure tomorrow anyway, so I'll plug a couple applications into it to see.
LT1Formula
20
11-14-2015 12:02 AM
Sanjay
08-12-2015 03:41 PM
