S_AUJP3 and Tuner Pro ?
I just down loaded Tuner Pro (allways used Tuner cat before) and the S_AUJP 3 bin, when you look at the 5,600 and the 6,400 Ve tables both of them are different at the same Kpa and rpm, Why is this? I know the 5,600 table is not used, but all tables are all the same in S_AUJP 1, 2, and 3. Is something off on the new table?
Jerry
Jerry
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
This is my fault. Sorry.
RBob states "The VE values in the patch are the stock AXCN values". I needed to change them over to the AUJP values. I didn't. Doing that now and then reuploading them. Sorry.
Tim
Tim
OK. This is done.
NOTE: Until I get Craig Moates to delete the old files be aware that the NEW files have the name in capital letters and the old files with inappropriate VE values are in lower case letters.
For Example:
New File = S_AUJP_v3.zip
Old File = s_aujp_v3.zip
Tim
For Example:
Tim
Originally posted by Mangus
I've deleted the old files. Should I remove the V2 files too?
I would say no. Let's leave them there for those that don't want the new hardcode changes. Coolio?
Tim
