S_AUJP Question
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
S_AUJP Question
I'm looking for the Super AUJP bin file for 350 and automatic transmissions. I found the 305 S_AUJP. I also downloaded some zip files that had S_AUJP in the title. I'm at work where my internet connection is so I don't have the stuff to open them and see for sure if I have the right stuff. I'm going to be on vacation next week and want to finally start doing some serious tweaking on my tune. Hopefully someone will recognize the files I have and will be able to tell me if I have the right stuff......
The files I downloaded are as follows:
SAUJP3.ZIP
S_AUJP_CCP_v2.zip
S_AUJP_v2.zip
Since nothing had the file extension of .bin after it, I wasn't sure if I had the right file(s). Being on my break at work, I don't have a lot of search time nor can I download and unzip these files on my hard drive. Thank the man upstairs for compact flash card readers and USB ports.....
SAUJP3.ZIP
S_AUJP_CCP_v2.zip
S_AUJP_v2.zip
Car: 1985 IROC-Z
What's CCP?
Also, I need the EGR in California (at least for the smog bin file.....)
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
The CCP is the canister purge solenoid stuff. you'll probably need that for CA smog.
There should be text files in the zip that give details on what was changed from the stock chip.
pretty good descriptions at that!
One file has the CCP the other does not.
The "V2" version had different IAC settings than the original S_AUJP. I haven't looked at the V3.
