Lt1 vs L98 spark tabel..
hmm im just curious. I wounder how much more timing the LT1 heads allow vs stock L98 alu heads, due to the reversed cooling system??
When I look at a LT1 bin ( from a 94 vette ) and my L98 bin (1991 vette ). I first notice how "smooth" the spark tabel is in the lt1 bin compared to my L98 spark tabel,that got alot more variation in it.
And as I cant find a "PE spark tabel" in tunercat for the 94 bin i guess it dont use one?
I can also se that the lt1 bin as far more timing in the low rpm@high MAParea (around 10 degrees more ) . And my L98 bin as alot more timing on crusie speed areas, 1800-3200rpm @ 40-55Kpa area.
Can anyone verify this, and perhaps explain it to me..?
1 Post
Car: 91 Red Sled
I can only tell you that the Lt1 combustion chamber and reverse cooling are both contributing to the higher advance. The cam also dictates some of it. With the tight LSA of the stock lt1 cam they can get away with more timing at high load low rpm.
That's all assumed so don't take my word for it.
The other reason you can't directly compare the 2 tables is like you said, there are other tables that are added and subtracted from the main table. PE spark, highway mode spark, low octane, and probably most importantly the cts table.
Too many people overlook the cts coolant table. With a "healthy" engine combination it's generally a good idea to nutralize a lot of tables to get a better tune faster. I tend to only add a few degrees at really cold temps and then remove a few degrees at temps where the engine is overheating (puts more energy into the exhaust than the cooling system).
Thanks for your reply.
Ok another ide...
Lets play with the ide that we put on stock l98 alu heads on a lt1 ( iknow you cant...). Do you belive you have to change the spark tabel alot to keep the car happy? Could the desgin of the lt1 heads be so "good" (diffrent) that the car would run bad, or perhaps even develop knocks?
Ok another ide...
LT1's have a better chamber and are rev cooled.
So the chamber roof temp will be different.
Also, the LT1 uses a different intake. Makes the lo rpm cyl filling completely different.
So everything is different.
I have vortec heads which are basically LT1's w/o the rev cool.
In carbed apps, they work just fine with as little as 28* total adv.
On my car, I saw only about 5 hp going from 28* and 91 octane to
97 octane and 34*. A more typical sbc timing #.
Proving to me at least that my motor was port limited and not CR limited, as everyone said I was. It's a 10.9-1 iron head 383.
im fishing here.
A miniramed/hotcamed car with aftermaket aluheads ( same comp as a stock lt1 ) L98, that would be simular to a lt1 (exept the cam )? I wounder how that engine would react on a stock lt1 spark tabel, (with all the PE spark advance zero out ). If the fact that a lt1 use optispark and r-cooling, would make the mod l98 develop spark knock and run bad?
1 Post
Car: An Ol Buick
Engine: Vsick
The idea is using the least amount of timing consistant with best performance. Start low, and slowly add.
Don't worry about what the LT1s or other people do, do what makes your engine happy.
True
Im just curious about the diffrent setups, and why things are like they are. And perhaps learn something on the same time.
As I try to build a complete new tune for my new engine, I have to understand the theory behind this. As unlike the VE where you have a WB to assist you, the sparktabel is somewhat a mystery to me...
cheers..
cheers..
im confused?? "everyone" say the lt1 can take more timing due to the reversd cooling system, right? But if I look at the super AUJP, and that bin has even more timing in to it? Im just curious about that..
TGO Supporter/Moderator
Car: '88 Formula, '94 Corvette, '95 Bird
Engine: LC9, 355" LT1, LT1
Transmission: T5, Zf6, 4L60E
Axle/Gears: 3.42, Dana44 3.45, 3.23
See that ^^^^
Thats about the best advice you'll get. Start with a stock timing table and slowly increase your spark advance until you slow down. Then back it off 2d.
If your motor needs 40d of timing, you either don't have enough compression, or enough boost.
-- Joe
The LT1 takes more heat out of the combusion chamber, so you add more spark or more compression ratio.
They do however stay cooler, so you have less chance of detonation.
The LT1's real strongpoint is the small chamber.. HUGE quench area, and less area for thermal loss. More heat pushing on the piston, not absorbing into a huge chamber.
-- Joe
Originally posted by anesthes
See that ^^^^
-- Joe
See that ^^^^
-- Joe
The LT1 is thermally more efficient. Sorta.
-- Joe
-- Joe
Im just trying to understand this, im NOT going to use a lt1 tabel for my engine.
-- Joe
-- Joe
So why is it then that a timing tabel for a stock LT1 is less aggresive then , for exampel the super AJUP?
The vette timing table exceeds the mechanical limits of the distributor. I don't get that.
I'd start low and work your way up. Forget about what GM did, or what Tim did in super AJUP.
-- Joe
I didn't jump on the super AJUP bandwagon sorry.
-- Joe
-- Joe
Yeah got it. Im going to start from the start. But cant se to find a good base timing tabel as my ""base" to start working from.
1 Post
Car: An Ol Buick
Engine: Vsick
I wounder what GM whas up to with that SA, if it like you say, that "The vette timing table exceeds the mechanical limits of the distributor"...
At least for the purposes of the 3rd gen distributor applications.
-- Joe
-- Joe
Originally posted by HaulnA$$
While 45 degrees may be the mechanical limit of a V-8 distributor, add that to say 6 degrees base timing and you get a total available advance of 51 degrees. The ECM would remove the 6 degrees base from the table value and apply 45 degrees advance from the previous DRP. This is in theory only and does not take into consideration the max advance limit Grumpy mentioned, which is usually set to around 42 degrees from what I have seen.
You have 45d between each terminal on the dizzy. And the higher the primary voltage, the more likely to fire that terminal from a farther distance away. It makes no sense.
-- Joe
1 Post
Car: 92 Form, 91 Z28, 89 GTA, 86 Z28
Engine: BP383 vortech, BP383, 5.7 TPI, LG4
Transmission: 4L60e, 700R4, 700R4..
Axle/Gears: 3.27, 2.73
45 deg timing is only at the crank, which would be 22.5 at the dizzy. But most cals have the max SA set to around 42 in the constants. The rotor tip and the cap terminal overlap for quite a wide range, and is probably in the advanced position such that even if you fired it 45 degrees advanced, it'll still hit the correct terminal.
i still dont understand why GM made the SA the way they did, I sure they got a good reason, but 46* at cruse speeds, that made me re-think about how to tune SA allover again..??
1 Post
I don't have my aluminum heads on yet, but that's probably the reason it's required. I know when I was tuning a 1.6L (I know, totally different), it wanted nearly 50 degrees in free revving neutral to run the smoothest (lowest MAP).
Gotta go
Gotta go
1 Post
Car: An Ol Buick
Engine: Vsick
If not you might as well study, VTEC, timing curves..
You need just to worry about what your doing, not what everyone else, or gm does.
Did you read the timing article I just posted a link to?.
Before you even think about trying to get even close to the extremes of how much timing you can run, you really need to study up on things, if your going with the max timing possible tuning chain of thought. Or have a thick wallet, you don't mind thinning out...
jerflash
09-24-2015 03:11 PM
mygta87
09-14-2015 10:36 PM
