can't get tunerpro rt to connect to ecm
Car: 92 RS, 05 GTO (sold), 10 TL AWD
Engine: 383 HSR w/DSC1
Axle/Gears: Strange S60/3.73
well I just switched mt car over from TBI to TPI and it runs but very poorly. before I switched over I could read data with WinALDL using my serial cable and my serial to USB adapter. now with the same settings it won't connect to the ecm using tunerpro. I have it selected to com 4 just like it was before. I have the 730 ads file selected. interface type is max232, and target sample rate set on 10hz. what am I missing here? I need this to work badly so I can finally drive the car. thanks in advance.
I had similiar problems, I went from 6870 TPI ECM to a 165 TPI ECM, and using a two transistor cable I cant link using tunerpro's ALDL feature. No probs at all with WinALDL. I am also using a USB to serial adapter and I have heard that the adapter is the problem. I would love for someone to prove this theory wrong so I can figure this out. Right now Im convinced thats the problem. I need to find another laptop to try that has a DB9 serial. Good luck and keep me posted on your progress.
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
If we're talking about 160 baud, then yes, the adapter is the problem (as USB adapters need to be opened at 4800 baud for 160 baud communications - currently TunerPro opens at 2400 baud, which works for serial adapters). This will be fixed in the next release.
However, if you're running a 165 with $6E, you should be using 8192 baud. If running a 7730, you don't have the option of using 160 baud, and theoretically your USB adapter should work fine. However, some of the serial->USB adapters don't like being opened at 8192 directly. if yours is one of these, this may be the issue.
gta892000
09-16-2015 12:37 AM
