motor is soft
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
motor is soft
when the motor is cool i can light up the rear tires for a *** 50 feet but after it warms up i am lucky if i can get them to spin at all. i have been tuning my ve tables and just about have avery thing around 126-130. i have a set of edelbrock shorties, a comp cam extreme energy cam 12-249-4 with .434 lift intake .444 exhaust and 206/212 deg at .05 this is on a 112 lsa and a holley tbi intake with the 670 on top with 65pph's in it. all on a 350.
would too small of a pump shot do this. if so what would a good place to start and how big of a step should i make when changing the pump shot.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Sounds like there is an issue with the AE. Since it seems to work ok cold try adding some more AE at high temps with the AE correction factor vs coolant table. MAybe about 5 or 10% around the temps that the motor has trouble and see if its the right direction to go in.
Engine: l98 and lo5
well my graph looks like this so i should add some about half way down the graf so that would be like .2% correct
what is the factor refuring to
Car: 88 Camaro SC
Engine: SFI'd 350
That factor is what the total AE is multiplied by once its all summed up. Id add it in around the areas that the motor normally operates at once warm.
1Aauto
Sponsored Vendors
04-09-2018 03:00 PM
1992 Trans Am
Exterior Parts for Sale
04-04-2016 12:50 PM
db057
08-11-2015 10:11 PM
