Stall Saver Spark threshold 1,2,3
1 Post
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
How does this work with the 165ECM and $6E ?
Would setting these values higher, prevent my stalling problem?
Currently, these values are set at 300, 300, and 450, respectively.
I have done a search, can I get some pointed help as this issue?
TIA
TIA
1 Post
Car: '87 IROCZ
Engine: 395 ZZ4
RBob,
So what you discovered was that the "stall saver" pretty well makes the engine stall if enabled. I will lower these values as opposed to invreasing them like a thought should be done.
That seems totally counter-intuitive to me. One would think that a "stall saver" would precent the engine from stalling out. Thank you for your help. I always appreciate it.
