454 tbi bin
454 tbi bin
I would like to take a look at a BBC TBI stock bin. Does anyone know what the name is and where I can find it?
I have looked at the diy-efi.org upload directory but I don't know what the code is for the 454 bin. or if it is even available there.
I have seen grumpy mention BBC chevy bins in some of his threads but I haven't been able to find one in my search.
Thanks for the help.............bob
ben, are there any addresses for later 454 ss models? ie 90 and up?
I went to diy-efi and found antz and anty. Man did they look wierd compared to stock 305 and 350 chips!
I was looking to see what the bpw would be on a bbc because I am going from 65# to 90# injectors and was just curious.
man, in those bins they used a 59 bpw compared to a 135 in the stock sbc bins.
can you send me to the site where you get the cal data report?
I couldn't find it on diy-ecm.
thank you for your help.................bob
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: check
Engine: check
Transmission: check
One is a stick tranny the other an auto tranny. Both used from '87 through '89.
{edit: there are some truck hacs on Moates site for the newer trucks}
RBob.
ben, rbob,
thanks guys......... I forgot to change the ecm on tuner cat from 61 to 42 so that was what was making the tables look wierd. I only do this as a hobby on one car so I make a lot of mistakes and am still a beginner on this stuff.
I can see the bpw now at 134. Man, do they have a lot of fuel in those engines in fuel table 1 compared to the 350 cop chip and my chip.
do you guys know which bin is for the stick and which is for the auto? I know you all can probably tell just by looking at the spark tables etc but I am not that good.
anyway, thanks again for the help...........bob
Car: check
Engine: check
Transmission: check
ben, rbob,
ben, rbob,
RBob.
