$58 The new linear WB02 patch
Syty.net post
Patches
Patches
Originally posted by turbodig
The new linear patches are now available for download at:
http://digware.lunarpages.com/
Click on the WB 02 link to download the patches.
Patcher itself is available via the Bin patcher link.
Let me know if there are any problems with the page or the patches.
The currently supported platforms:
PLX 300/400/500 series linear output
AEM Gauge-type Linear Wide Band (Non-gauge type requires a different patch)
Innovative LM-1 Linear output (requires programming)
Tech Edge 2.x Linear output
Raw Data output
Please note that these patches are for non-commercial purposes only.
They are not to be included as part of a commercial chip offering.
Later,
Dig
Raw Data output
Later,
Dig
Car: 93 GMC Typhoon
Engine: 4.3L V6 Turbo Charged
Transmission: 4L80e
I helped Dig test these. The ECM still uses the NBo2 to make its corrections. This is so you can log your WB output with any ALDL scan tool. The WB AFR shows up in the AFR TGT/VE field and the RAW DATA coming into the ecm from the WBo2 is displayed in the EGR TGT field so you can see if you are getting data.
You'll need to wire your WBo2 output into Pin F14 on the 749 ecm.
forsete
Car Audio
03-22-2001 12:23 PM
crazeinc
02-14-2001 09:03 AM
