Cheap AF Meter.. no, it's NOT what you think!
#51
Car: 82 Corvette
Engine: 350 CrossFire
Originally posted by jfreeman74
When the center LED is lit, is that "approximitely" the same as a 14.1 AFR? If that is the case, when you are at WOT the AFR should be around 12.7. How do you know that is the case? It seems like it will just show a Rich at WOT which wouldn't be the case. Maybe I am all wrong with this. I'm not sure.
Keep in mind that the rich area changes in coordination with EGT.
#52
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
#54
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
Can you run it on the same O2 sensor the system is using?
No problems with an additional load on the signal?
#55
Car: 82 Corvette
Originally posted by edfirebird
What email/account should I send the paypal to?
Ed
Ed
#56
Car: 82 Corvette
Originally posted by Ken73
We've also incorporated a high-impedance op-amp as a buffer so that there's hardly any current draw on the O2 sensor, a problem with some of the other methods since it interferes with the ECM's operation.
#57
Just reading some new posts on the A/F meter.
What I wanted to ask is if you are LEAN will all 10 LEDS light up on the LHS and if you are RICH will all 10 LEDS light up on the RHS?
Or will it depend on how LEAN/RICH you are that maybe only 1-10 LEDS will light up?
I think maybe this is what Mangus was talking about?
So if I am only a little lean will all 10 LEDS Light up or will only say 3 of them light up?
#58
Car: 82 Corvette
#61
Car: 82 Corvette
Found a A/F metrer here for sale but going by the description not really sure what it is capable of. Also seems to be set for a specific EGO Probe. Just thought I would post it up for you guys to have a look at it.
A/F meter
A/F meter
#63
Car: 82 Corvette
Just a new note:
I made it up to Grumpy's this weekend and paired my AF meter up with his DIY-WB (do it yourself wideband, for those of you not familiar.) While it was obviously nowhere near as accurate, it was definitely adjustable to where it probably will be semi-close. The resistor values for the gap and top/low end in reality aren't "set in stone" (hence the spreadsheet.)
I *KNOW* they need tweaking to be a little more accurate, but I'm going to need use of a wideband to get it close. The good news is, it's just a couple of resistors that are easy to solder out/in.
#64
And this is using a narrow band lambda? Heh, cool… I was just hoping for something that would give me a hint of where I was at, something approaching accurate is a bonus. I’m not sure why no one has ever tried to do something that scaled with the output curve of the sensor before, seems obvious.
Keep us updated on the new values, I suspect that it will be a couple of weeks before I have time to assemble mine, so I might as well go “latest and greatest” with it.
#65
1 Post
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
Keep in mind, that the output of a lambda O2 sensor varies significantly with EGT, so resistor values developed one particular car may not necessarily carry over to others.
What would be better, is to compare it to a WB on the actual car it's going to be used on, to get an idea of how it compares. Even then, keep in mind that the limitations inherent in lambda O2 sensors still apply -- Ken & Bill's meter is cool, but don't expect it to make a NB into a WB!
(BTW, got my boards, and ordered parts last night )
#66
Car: 82 Corvette
Originally posted by 83 Crossfire TA
.....seems obvious.
.....seems obvious.
Dave is very correct about EGT affecting the sensor curve, but it's generally the upper (rich) portion. We might make a compensated one later, but it's STILL not going to be accurate like a Wideband.
#67
1 Post
From "Internal Combustion Engine Fundamentals", by John B. Heywood.
#68
Car: 89 Shortbox
Engine: 350 Vortec
Question about assembly,
Do all these capacitors have polarity?? Or can they just be placed in either way.
#69
Guys,
Quick question about assembly of this unit.... I finally got around to soldering everything together and when I powered it up the only LED that lit was the center 'stoic' LED? Is this working properly or should all the lean LEDs light up with power to the board but no O2 sensor connection? I haven't had a chance to hook it up to the car yet, so I'm just wondering. I triple checked all the solder points and everything looks good.
Thanks for any help,
Rob
Rob
#72
1 Post
Originally posted by R_Andersen
How do I determine which way to install them?
Rob
Rob
#73
Thanks guys. I put all the LED on the board in the same orientation so I'm sure I have all the 'lean' LED's backwards. I'll get some more and put them on in the other direction and I'm sure it will work fine then.
Thanks,
Rob
Thanks,
Rob
#75
Your BOM is for 10 yellow leds but your pic shows 10 green and one yellow besides that I'm gonna use a sharpie to blacken them it reduce blled through. Kewl meter the pcb is a bit fineky when soldering.
Ed
Ed
#76
1 Post
For dealing with the LED bleed through, I ended up just using some black enamel paint on the sides of the LEDs. Doesn't take that long, and seems to work better than an ink marker.
If that's not enough, glue on some squares of metal foil
#77
Car: 82 Corvette
I just used a Sharpie. Worked fine for me.
It's definitely a pain to solder, an Optivisor or loupe helps immensely in making sure you don't have bridges.
The BOM discrepancy is just a color preference; Bill wanted 10 yellow, I wanted 10 green. (Green for power, red for lean.) You can use any color combo you want; green in the middle, red on the ends.. it's entirely up to you.
#78
Just one last question on the LED polairty... On the LED's, one leg has a flat depression while the other does not. It this leg the anode or cathode side of the LED? I can not go by length of the legs since mine are already cut.
Thanks,
Rob
Thanks,
Rob
#80
Yep, put a DMM in "diode" mode and put it across the LED leads...when the LED lights up (very dimly) then the positive meter lead is on the anode and the negative lead is on the cathode. The "depression" on the leads means nothing.
#81
Ken do you still have kits ready to ship?
WTB a kit or two. Are they still 40 shipped and how many do you have avail can would you do 3 for 100. A buddy saw mine now he wants two.
Eddie
P.S. These are great visual feedback for SOTP tuning lol
Edfirebird68@aol.com
Eddie
#82
Car: Pontiac
Axle/Gears: 3.08 / Drums
I kinda want one of these kits but it'll be a couple weeks and I have a question: Is the output of the sensor a log function, or is this setup just sort a good approximation to get started tuning with?
Damon
09-26-2015 04:29 PM
