Help translating ALDL Data
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
I recently swapped my 100K+ L03 for a mildly built-up 350. The day I picked the car up it ran fine. Ever since though I've been frustrated by a rough idle -- eventually stalling out.
Which is followed by a hard starting condition. (unless i put the car into "clear flood mode") which then only idles if I manually hold the car at part throttle, say 1500 RPM's or more.
I've replaced the fuel filter, and IAC,
I've taken the fuel pressure at idle: 11 PSI
I've rebuilt the throttle body, serviced injectors, and replaced the thermostat
I have the most recent datalog available here.
http://www.claresco.com/clients/ALDL_Data/AldlData.txt
I only chose these fields to post, however I have the entire log if anyone needs a more complete picture.
Right around the 162 second mark, (less than 3 minutes after start) she dies. I see the IAC is closed ? But I could really use some help pointing me in the right direction.
Any and all help is appreciated !
Thanks.
1991 Firebird
350 sbc
218/224 @ .50
Edelbrock Performer Intake Manifold, heads, and headers
Single 3" Cat, Flowmaster
Thanks.
1991 Firebird
350 sbc
218/224 @ .50
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
well, no one bothered to reply. . . guess my post wasn't worthy.
In any case i've found some help in the TBI forum, and moved the post here
Feel free to delete this thread.
Car: 1980 Jeep CJ7
Engine: AMC 360 with GM TBI
Transmission: TF727 set for kill...let's get it on!!!
I for one never saw it. Where are your BLMs and your INTs? Those are very important in the grand scheme. What about knock counts? You'll be needing that too.
Car: 1991 Firebird
Engine: 355 TBI
Transmission: WC-T5
jeepguy553,
hi, like i said i've moved the post here . . .but the full datalog is available . . .here
On the advice of the chip company, I tried adjusting the throttle stop with the IAC fully extended and unplugged. I raised the throttle stop until the engine quit sounding like it was on the verge of dying -- according to the log that shows a TPS value of around 5% (.74 volts ?), as opposed to the stock value of ~.5 volts.
I understand this is configurable in WinALDL, and have no idea what my setting is, so i left it at default .54 at 0%. I've posted these datalogs .here
