Lean Cruise mode
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
1 Post
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Do a search for highway Fuel and highway Spark
tons of info and various patches floating around here..
From my experience it will not gain u anything or can actually hurt your mileage unless your tune is about dead on perfect
Later
Jeremy
Later
Jeremy
1 Post
Car: 91 Red Sled
My car specific, I've seen an average 16 mpg highway without it and 20+ with it. When I was going to the extream I was able to push 23 but as of lately I've backed off a little, run cheaper gas, and have 21 to 22 mpg every trip I've made from NJ to Ohio (540 mile trip one way).
My tune has never been perfect so maybe it's just this mask that does as well as it does. Even when my BLMs were in the mid 130's, still got same milage. Then when my BLMs were in the teens and low 120's, same milage.... just goes to show you how different GM ecm's really are.
I see. I guess thats why GM didnt use it because of the danger of running too lean. Since every motor is different, you can tune lean cruise to your application. Thanks guys.
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
Originally posted by RBob
IIRC the LO3 TBI f-bodys have lean cruise enabled from the factory.
RBob.
RBob.
Also, if you have an agressive spark table, don't use Highway spark. It's designed to add more spark and if you add more to make your total over say 41deg, the car will do weird things.
At one point when I hit highway mode it'd trigger an o2 sensor code and make the car bounce and almost die.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Yep, all the L03s had it enabled. Doesnt matter much for me, still use assloads of gas whether its enabled or disabled.
Car: 1980 Jeep CJ7
Engine: AMC 360 with GM TBI
Transmission: TF727 set for kill...let's get it on!!!
Is there a particular flag or set of tables I can work for this feature in $61?
Good thread, One of the reasons I am swapping to fuel injection is for the mileage gains. Today I leaned out the primaries so I would have a 14 afr down the freeway. I pulled 28 mpg with the 430 hp crate motor. I cant wait to get back to fuel injecton, should put me around 30 mpg
![Smilie](https://www.thirdgen.org/forums/images/smilies/smile.gif)
Car: 1980 Jeep CJ7
Never mind. I found it. I hadn't ever really noticed it until now.
