alot lost on programming LT1. help pls.
Car: 89 GTA
Engine: 350 LT1
I have a 96LT.. going to run 94 Computer.. Looking at Tunercat.. don't know if i should be..?? looks like I need
$EE Ecm File
Tuner Prgram..
we'll assume I can get /make a cable..
what am I missing .. or am I in the right pew.. wrong church?
$EE Ecm File
Tuner Prgram..
1 Post
Car: An Ol Buick
Engine: Vsick
Yes, you want an EE .tdf file for editing the OBDI LT1 flash pcms.
Try AKM cables. A search or goggle should find him.
You want the cables right, since any booboo during flashing, locks up the PCM.
Car: 89 GTA
Engine: 350 LT1
i saw that webpage.. think i can do my own.. but if not.. ill get their cable.
It was suggested I get 2 PCM's .. is there a need for this?
also.. is there anything else I need? software / hardware wise?
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
Spare ECMs are a good idea... Never know when might go sideways on you. The PCMs tend to lock up if something fubars during a flash dump. AFAIK theres no DIY way to wake one back up if this happens. BW
LT-1 question: I keep hearing talk of "early" LT-1 computers having a removable chip which is programmed and then reinstalled, much like the earlier ecm's. I then looked at an 8051 pcm which did have a little removable device under a small cover but with only 5 or so pins on it. The LT-1's are programmable but only thru the OBD1 connector, right?? And this talk of removable and programmable chips for the LT-1 is old wives tales??
Steve
Steve
Car: 89 GTA
Engine: 350 LT1
i think what you see under the cover is the knock sensor.. but if their are removable chips.. that would be nice... anyone know??
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
I wish I had OBDII Now that most emissions stations have switched over to scanning the ALDL port for OBDII (as opposed to actually measuring the emissions) it is rather easy to make a car pass emissions. The OBDI setups still have to get the actual emissions tested.
Tim
Tim
1 Post
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
Steve
Steve
In '94, things went to MAF, and FLASH, and transmission control was added (i.e 4L60E), so the '8051 is more correctly referred to as a PCM, rather than an ECM.
The removeable device you saw on that '8051 was the ESC module, for the knock sensor circuitry.
BTW, if you're referring to the '92-'97 EFI engine, and not a carbureted smallblock from many years ago, it's "LT1" not "LT-1", at least if you care to follow GM's nomenclature. (nevermind the fact that half the aftermarket gets it wrong, too.)
1 Post
Car: An Ol Buick
Engine: Vsick
Tim
Tim
Not to mention all the VIN locking the newer stuff is doing.
1 Post
Car: An Ol Buick
Engine: Vsick
Originally posted by Thirim
good to know you can screw it up.. ... what's it take to repair one should it lock up?
3.8TransAM
09-27-2015 08:37 PM
8051, chip, eetdf, engine, flash, lost, lt1, pcm, programing, programmable, programming, prom, repair, tdf, tunercat
