Limp home mode causes
Car: 1980 Jeep CJ7
Engine: AMC 360 with GM TBI
Transmission: TF727 set for kill...let's get it on!!!
What kind of things will put the ECM into limp home mode? I just swapped ECMs and I STILL can't get any datalogs in WinALDL or TunerPro RT. This is bizarre.
1 Post
Car: An Ol Buick
Engine: Vsick
Re: Limp home mode causes
There's actually 3 ecm modes, normal, fail soft and limp home. LH meaning that the ecm isn't using the processor, and is using the other analog hardware in the box.
Might try disabling all the malfunction flags and see if you can get it to link.
Car: 1956 Willys
Engine: 383 TBI
Transmission: SM465
Re: Re: Limp home mode causes
Originally posted by Grumpy
Just about anything.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
1 Post
Car: An Ol Buick
Engine: Vsick
Re: Re: Re: Limp home mode causes
Originally posted by brennanw
Got any idea what mode is used when the timing wire is disconnected for setting the base timing?
The processor is still in the loop.
Car: 1980 Jeep CJ7
Originally posted by dimented24x7
Maybe something wrong with the cable or the computer (PC, not ecm) your using?
1 Post
Car: An Ol Buick
Engine: Vsick
This may very well turn out to be the case. We'll see in a few days. I just got a "new" laptop, though and I find it difficult to believe that TWO PCs could do EXACTLY the same thing. I also just got a new ECM...it's in the ECM clinic for minor outpatient surgery. We'll see how it turns out when the ECM is discharged from the clinic.
Just never say never, or assume anything.
Car: 1980 Jeep CJ7
That sucks, Grumpy! It sounds like you luck is running the same course as mine lately.
Once all these little bugs get ironed out, it looks like everything should be great. Spring break is coming up and I'll have about 10 days to goof off and work on the Jeep. ECM tuning....cage welding...maybe an axle swap or two...
Car: 1980 Jeep CJ7
Bill, check your PMs. I found you a D300 xfer case...sorry for the OT post guys.
RedLeader289
05-28-2019 01:47 PM
