IAC thing revisited
Car: 1980 Jeep CJ7
Engine: AMC 360 with GM TBI
Transmission: TF727 set for kill...let's get it on!!!
IAC thing revisited
I have a TB that came with my Holley ProJection system. I am definitely NOT using the ProJection, but the TB looks like it will work with the rest of the GM electronics...except for the fact that it is missing the IAC. I have seen several posts that talk about not using the IAC on a TBI engine. So...could I use the 670cfm TB with the 1228746 ECM I got today or is that a dead end deal?
TIA...
TIA...
Car: An Ol Buick
Engine: Vsick
Re: IAC thing revisited
TIA...
TIA...
The FWD Vin3's, just to name one, starting in 87 have a removeable IAC housing, so with a small AL plate or some Epoxy you can easily make one.
Car: 1980 Jeep CJ7
The IAC bore isn't even there. Maybe I should post a pic of it so you can see what I am talking about. The problem isn't with the IAC and a vacuum leak. I am wondering how the ECM would react to sudeenly learning that it doesn't have an IAC. Can't the IAC steps be zeroed out in the BIN to basically cause the ECM to not do anything with the IAC?
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Jeepguy,
You may want to do a search, or ask around on the TBI board. I know there are some guys over there doing without the IAC.
Personally, I would want a functional IAC for stuff like cold starting and A/C rpm compensation, but I'm sure things will work without one.
Another question to throw in here, would the Idle motor off a Mopar TBI engine work on a GM ECM? I know they used one on the Dakota 3.9 (Only application I'm sure of!) it bolts to the TB, and opens the throttle blades, instead of a bypass setup like GM uses. Maybe an older Cadillac motor if you wanted to keep it all GM (although Mopar would be closer to what Jeepguy already has! )
Car: An Ol Buick
Engine: Vsick
But you might double check a hac on that info..
Car: An Ol Buick
Engine: Vsick
Usually called a Throttle Kicker, FWIW.
Car: 84 Z28
Originally posted by Grumpy
That's what some of the projects had, lots of carbby applics had them for A/C load compensation, and for overrun.
I'm very familiar with the throttle kicker solenoid, my car has one (until I get the EFI on it!)
Car: 1980 Jeep CJ7
I may disconnect it and see how the ECM reacts. If it doesn't cause any problems, I may put the Holley TB on the engine and see what happens.
Car: An Ol Buick
Engine: Vsick
Nah, I'm talking about the stepper motor that they used on the Cad's, and Mopar's. I would think it would work exactly like an IAC, I'm just wondering if the IAC driver would be strong enough, I think they are a bigger motor.
Now that's real garbage, IMO.
Use the Throttle Kicker, it's much less prone to failure, or erratic idling.
Car: 1980 Jeep CJ7
I could put a kicker solenoid on it. In fact, there already is one on the Holley TB. I could use that solenoid for kicking the idle up a few rpms when the A/C is on or I am using the on-board air system.
my set up uses two IAC. one is non functional(broken). so my warm up and AC is 1/2 of what it should be on rpm. i ran with it disconnected(plugged bleed lines) for a while and set min idle in constants at 650 rpms. since i have a manual trans i could live without it as high speed idle was foot controlled. with air on idle was a bit too low but never died.
Car: 84 Z28
Oh, the ISC?.
Oh, the ISC?.
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
I took one of the holley TB and just drilled the hole for the IAC. The outer was like 13/16 and the inner was 3/8. Then you have to have the hole threaded. Most machine shops have the right tap.
It's an easy surgery!! All the TB's I have seen have the casting for the IAC, it's just not drilled and tapped.
If it has the back facing TPS then just put your GM one on it.
HTH
HTH
Car: 1980 Jeep CJ7
I think I am gonna put that TB on there in a few days and see what happens. I may go poking thru the BIN and try to neutralize any IAC related stuff in there before I do it.
Car: 1980 Jeep CJ7
HTH
HTH
It does have the back facing TPS too. Hmmm...this is getting better and better as it goes.
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
I used a 5/16 IIRC then finished it with a tapered stone. But to tell the truth. The IAC pintle is tapered so it would seat well enough on a standard hole. Sort of like a valve seat. Think about it. Does the IAC go to zero very often?
Not on mine.
Just verify the measurements. It's been a while since I did mine!!
HTH
Not on mine.
HTH
Car: 1980 Jeep CJ7
How far down into the TB does that hole go? Is there a passage cast into the TB for the IAC bleed?
Car: An Ol Buick
Engine: Vsick
Not on mine.
Not on mine.
A straight cut hole is fine. It's not really critical is there is a slight air leak there.
The pintle has to be talered other wise it would be just an on/off devise.
Car: 1980 Jeep CJ7
You know, I have a set of pipe thread taps. I bet I have the right one...and I do have a drill press with a vise so I could chuck the TB up on the press and do the drilling that way to keep everything in line.
Car: An Ol Buick
Engine: Vsick
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
It's definately not pipe. I do have an IAC that is threaded with pipe threads. Now how do you suppose I know that!!!
And why would I have an IAC with pipe threads???
DOHHHHHH
If you look at the TB you will see exactly how it works.
Drill the outside hole for the threads. the IAC screws in and seals this hole back up.
drill the inner hole. Air comes down from the top of the TB inside the air cleaner, through the hole, the IAC is positioned to control the amount of air passing the pintle, then into the intake.:lala:
IIRC mine was more like 24mm, almost 1 in. My plugs and O2 bung are 18MM.
DOHHHHHH
Car: 1980 Jeep CJ7
I just made my O2 bung out of a 18-mm plug non-fouler. I also just got (Sunday) a nice, shiny new Lincoln MIG welder. I wonder what kind of projects I can think up to put THAT to work on...
I better go look at that Holley TB. I really don't think that there is a passage from there to the intake meaning it would probably have to be drilled into the TB itself.
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
I use the anti fouler also. i just cut the threads off.
"I really don't think that there is a passage from there to the intake meaning it would probably have to be drilled into the TB itself."
I'll bet you that new shiny welder!!!
Car: 1980 Jeep CJ7
Car: 1980 Jeep CJ7
You would have won, Bill...here it is...this is the side view. I will definitely have to put the GM TPS on it if I do this.
Car: 1980 Jeep CJ7
Nope...only a little 100...but you could do a SOA in ultiple passes with it I think.
Here's a pic of the TBI AMC 360
Car: 1980 Jeep CJ7
How bout a dana 300??
Car: 1980 Jeep CJ7
Now that I have THIS...clicky clicky I can do just that.
Car: 1980 Jeep CJ7
Maybe we should take this to the TBI forum...why put the GM injector pod on it?
Car: 1980 Jeep CJ7
Lemme see if I can sound like Crocodile Dundee...
That's not an ignition coil....now THAT'S an ignition coil:
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
Cause the old Holley inj's suck!!
You already know the GM inj's are fine for your motor so just make the adjustments for the increase in air volume when you add the 2" TB.
#43
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
I now have a JY ford TFI coil. very cheap and supposed to out do the GM HEI coil by a bunch
#44
Car: 1980 Jeep CJ7
I agree...I really like the TFI coils...that Accel coil I posted is just a TFI on steroids.
#45
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
I see...and you get the GM FPR too...
Just twist the round bottom until it spins then run the indicator tab to the top of the slot. Then check with a FP guage. Should be around 15psi!
#48
Car: 1980 Jeep CJ7
Okay...let's not get started bashing Jeeps... I get enough of that from my wife...really. She hates it.
How much tweaking did you have to do to make the ECM like the 2" bores?
Oh yeah...did I mention the 727 tranny under the Jeep? And the LARGER AMC 360? I found a set of Dana 60s this weekend...now I have to get my friend's dad (they own a junkyard...Jeep parts gold mine) to let me take em off his hands. He did GIVE me another 360 engine...complete...in trade for an old TH400 tranny I have.
#49
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
It didn't take much to change at all.
These old IH's are low rpm motors. so the 2" bores really only affect the top end and a little AE!
The motors are governed by the valve springs at 4000rpm.
Just got a set of LS6 BBC springs for it so I should see 5000 shortly.
Find me a D300!!
I just picked up a jeep 727 tailshaft and housing to bolt up a J@@p 300.
Are you logging with the new 8746 yet?
Find me a D300!!
#50
Car: 1980 Jeep CJ7
Nope...long story there...offline.
If you need a few pointers on opening up that 727, let me know. I rebuilt mine almost 3 years ago and it hasn't even burped yet. I did it for less than $200 in the backyard shop at my in-laws' place in the middle of February...new converter and all.
