cam tuning question
#51
Car: 73 chevy truck
Engine: 406 11.6 comp 2.02 heads
Transmission: stock th350
how do you find out the amount of overlap a cam has? 11sorbust your car gets 20+ mpg damn thats good. what does your car run in the quarter? what do you think of this cam? http://www.compcams.com/Technical/Dy...84H-10_001.asp
im tuning a 406 with tpi for my senior project any suggestions?
thanks
thanks
#53
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
thanks
thanks
http://cochise.uia.net/pkelley2/dcrvb6.zip
#54
Car: 86 camaro z28
Engine: 350 tpi
Transmission: 5 speed
Axle/Gears: stock junk
Re: cam tuning question
heres my problem i have a 86 tpi 350! The guy i got it from said it was bored 60 over has a healthy cam and flowtech heads with roller tips it also has no cats and has a magnaflow exaust! The car doesnt want to start unless u feather the gas and when it does start it will surge and stall unless u keep the trottle down! And it wants to run hot i know all the plastic is gone under the front end but could the cam cause it to run hoter if not working right with the engine! Ive read all the post on thirdgen.org about tuning one but i really dont understand the concept of it could someone please help!
#55
You need to study the 'stickies" above. Some applies to you some not. "Come in for free tune" sticky in TBI section may not apply to you in total but is good read as it discusses the basics of EFI tuning. First step is to locate a ALDL cable download winALDL or TunerproRT and datalog that engine. Your sensors will give you info as to what needs to be tweeked.
