TunerPro and TunerPro RT v3.05 released
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Its that time again. In anticipation of the first production AutoProms arriving in the hands of end-users (tomorrow), I've released TunerPro and TunerPro RT v3.05.
http://tunerpro.markmansur.com/
There's a lot of new stuff this time around. There's likely to be some issues here and there, so, as usual, please feel free to make me aware of them.
TunerPro Free
- fixed issue where user wasn't being prompted to save new checksum (if optioned) on program exit "Bin Modified, Save?" prompt.
- When an ECU Item is edited the Summary List and ECU Editor Toolbox get updated if they're open.
- Added preference option to keep the graph window always on top.
- Added hex editor (ctrl + h). You can make changes and save them to the bin in memory. Changes aren't saved to file unless you do so in the file menu. Loading the bin into the hex editor may take some time on slower computers.
- Fixed obscure issue with main/summary list interaction in some situations where it wouldn't allow you to select an item if the summary and main lists were both showing and the item had a counterpart with a similar name.
- Fixed a *bunch* of ECU editing/manipulation related bugs. Thanks Matt!
- Fixed crash when hitting escape while dragging an item in any main list.
- Compacted 3D tables a bit. They take up less workspace area now.
- Fixed table fonts in win9x. Fonts look much better now.
- Made minor changes to the ECU Item Editor
- Fixed something I broke at some point. when changing selection in table editor, graph is now updated with selected point.
- Fixed installer issue where core .exe wasn't being replaced if it existed. This resulted in unsuccessful upgrades without uninstalling first.
- Added some importants stuff to the included 6E ECU file. Version is now 11 (6Ev011.ecu). Some added items include MAF table scalers, mask ID (for easy checksum disabled), more IAC params, etc. Added because I needed them.
- Other minor stuff that I forgot to document.
TunerPro RT
- Added ALDL Datastream Definition Editor. Provided you have information on your vehicle's ALDL datastream, you can use this to create a definition for TunerPro, allowing you to connect to you car with TunerPro. The editor allows you to add items, delete items, re-arrange items via drag-and-drop, add/delete/change connection strings, add item/definition comments, etc.
- Added support for 160 baud ALDL data capture.
- If emulating, changes made to a graph (2D/3D) are automatically updated to the emulator upon mouse button release
- Added prelim, temporary AutoProm A/D capture interface.
- Changed the Bit Data interface (took away a column, but added the ability to label set/clear bits)
TunerPro Free
TunerPro RT
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Hey Mangus you have a killer Program but for some reason after I download 3.05 and try to install it I get this error.
I am using Windows XP
Transmission: T5WC
wow, thats one I've never seen before. Did you try re-downloading?
I took down TunerPro RT temporarily. Discovered a bunch of Win98 issues (why does this always happen *after* I release and not before?! Grrrr!).
Car: 1980 Jeep CJ7
Engine: AMC 360 with GM TBI
Transmission: TF727 set for kill...let's get it on!!!
Win98? I downloaded it to a Win98 machine earlier and it didn't seem to cause any problems. I also downloaded it to my XP machine and it seemed to work fine.
I hope it will work with my Win 95 laptop that has only 8MB of EDO RAM....
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Tis ok U will Get it
Just Keep On Keep N ON
oh BTW i Reinstalled 3.04 since 3.05 Wont work for me yet and 3.04 works fine
Transmission: T5WC
the issues are related to the AutoProm. Should work fine otherwise.
Your system is well below the recommended specs. You're going to want at least 16mb of ram. also, you won't be able to register on win95.
Transmission: T5WC
Originally posted by MTPFI-MAF
I redownloaded it 3 times to make sure
the usual questions apply:
what OS?
what browser?
download utility?
Car: 1980 Jeep CJ7
TunerPro RT V3.04 seemed to work on it...slowly...but it worked. I guess I can take my Win98 desktop to the garage for initial tuning and such. I can datalog with the Win95 machine and WinALDL if I need to.
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
i just re-downloaded both free and RT and installed without a problem.
what OS?
what browser?
download utility?
what OS?
what browser?
download utility?
Browser: MSN9 am trying IE6 at this moment
windows download utility
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
ok It is a Error within Msn9 Browser It downloaded and installed Fine With IE6 Sorry about that but now we Know.
Transmission: T5WC
bin stack feature question....
I am having some trouble stacking bins using the tunerpro stacker. I am trying to load (32) 16k/6E bins onto a 29F040 chip for use with my moates GP3 switcher.
In tunerpro, I "browse" and selected the bine files as I saved them. They show the bin location correctly on the line when selected and each one says 16384k as file size. I do the same 32 times to fill all the fields. I have "bin size-16K, chip size 512k, switch block size 16k" selected as this was the only way to allow 32 16k bins to be selected. I choose "save layout as" and saved the .bsl file. Now when I view the file it shows in properties a file size of only 9k.
When I open it in the eprommer software it doesnt look right either. It has about 4 lines of code followed by a few lines of zero's, 32 times.
What am I dong wrong, someone please help me out..
Transmission: T5WC
32k block size is needed with the moates adapter. thus you can only stack 16 bins in an F040.
