Does my ALDL cable look right?
Car: 91 RS
Engine: LO3
Transmission: 4L60
I'm trying to get data from WINALDL, but I get nothing. I disabled all the other ports on my laptop except COM1. The 4th pin on my DB9 output was only reading 6.2 V with WINALDL running, so I built the externally powered cable from JoBy's site. It was easy enought to build, but it isn't working. The cable is only about 4ft long. I was wondering if you guys could look at my cable and tell me if it looks like it's soldered together properly.
I know it's ugly, but does it look like it should be functioning?
Car: 91 RS
Engine: LO3
Transmission: 4L60
Nevermind, I took off the 1.5 K resistor and it started logging data. Either that, or it miraculously fixed itself.
Car: 82 Corvette
Engine: 350 CrossFire
The 1.5k resistor is for CLCC (Closed Loop Carburetor Control) systems, not for fuel injection systems which used a 12 volt swing instead of a 5v swing in voltage.
Car: 1999 Chevy Cavalier
Engine: 2.2
Transmission: 5 speed
Axle/Gears: it's part of the transmission
The soldering looks fine, but those components would really rather be mounted to a small PC board.
Car: 91 RS
Engine: LO3
Transmission: 4L60
JYD - that's a good idea. I will just consider this Franken-cable to be a prototype or soldering practice. Based on your suggestion, I will build a more aesthetically pleasing version.
It works, though, and I got my first data logs this weekend. I logged data at a variety of different base timings to see where I start to knock significantly. I think that I can run 6*btdc on premium fuel. I would like to get into DIY-PROM, but I don't have the necessary equipment to burn chips.
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Can I borrow that pic? I'll refer people to it when they ask how hard it is to build a cable. Pretty cool!
Car: 91 RS
Engine: LO3
Transmission: 4L60
About that 1.5 K resistor...It's funny, I looked back at the schematic I used (from Jonas's site) and it says in big, bold, blue letters that the 1.5 K resistor is only for some carbed vehicles. In my haste to build the cable, I didn't read it carefully.
JYD - I constructed a more compact and robust cable using a perforated board. Is that what you meant by a PC board or did you mean an actual circuit board?
Craig - I'm really glad that you see some value in the picture. I enlarged everything on that first trial build so I could understand it. By all means, everyone is free to use it, reproduce it, publish it or whatever you want. I hope it helps someone.
Z28/ZR1
10-23-2015 01:04 PM
TMZIrocZ350
10-07-2015 12:09 PM
