New Chip; Computer Not Responding with AutoXray
Car: 1991 Z28
Engine: 5.7
Transmission: A4
I starting messing with chip burning this weekend and ran into a problem. I read on the board about changing the constant on my FI size to 24 lbs. Also, I read how to change the constant to disable the EGR. The problem I have it that once I put the new chip with the Moates adapter and factor chip piggy backed it throws the check engine light solid. It also will not let me use my AutoXray to see what the problem is. It tells me when I scan that the computer is not responding. I disconnected the battery when I changed out the chips. I believe I have the chip in right. Once I take the chip out and put the factory one back in everything is okay. I even went back and verified the settings by taking the bin off the burnt chip and viewing it. I believe that the bin file is making it on to the chip. Any ideas would be appreciated. BranZ
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Sounds like a checksum issue. Be sure your checksum is calculated and updated correctly.
You can disable the checksum altogether by setting the mask ID to AA.
Car: 1991 Z28
Engine: 5.7
Transmission: A4
Mangus I am confused
I am confused on where exactly to change the Mask ID. Mangus where do I get more information on how this part of it works. Did I miss it in Traxion article. Please give me some more detail. Thanks, BranZ
Transmission: T5WC
in most applications (6E for instance), the mask ID byte is the 9th byte in the bin. i.e, the 9th byte (starting with 1) is 0x6E. Set this to 0xAA and the computer won't acknowledge the checksum.
Car: 89 Irocz
Engine: 350TPI $6E
Transmission: T5WC
yeah, i have, thanks. only so much time in a day. your PM was "read this 35+ post thread and help me".
I'll reply when I have more than a minute or two free. :-D
Gunner242
12-25-2015 04:49 PM
Damon
09-26-2015 04:29 PM
