v6 commodore
Re: v6 commodore
Originally posted by hinterland
does anyone no wat software i need for a vt 1998 commodore v6
I have a VS V8 manual Commodore SS with the last of the '165-like ECM's. Some of the editor software that blokes on this forum use (eg Tunerpro or Winbin) will support it with the right ECU file.
You have a PCM that also controls the auto transmission as well as the engine. I don't know of any .ECU files that you could use with the usual editors on your PCM. It will be interesting to see if you get any other response.
If you can get a Caldata sheet, it's possible to make an .ECU file from it. There are alternatives, but they're over my head at present.
Kalmaker has a system that uses their modified '808 code IIRC. Other than that, you're stuck.
John
Car: vt commodore
Engine: v6 turbo
Transmission: auto
THANKS
thanks john ill keep hoping someone can help me i might have to pay the 1600
for kalmaker workshop
Car: vt commodore
Engine: v6 turbo
Transmission: auto
um no not realy but nice try good to see someone with sence of humor im still looking
Car: vt commodore
Engine: v6 turbo
Transmission: auto
any clues
here is link for eprom programer would any one no if it is going to do the jod
unshore http://newfoundelectronics.com/warp-13a.htm
Car: vt commodore
Engine: v6 turbo
Transmission: auto
a fellow ozy
Originally posted by Tomcat
I use the pocket programmer for the VT stuff but it is a little erratic on the stock eprom 27c010
any chance of gettin bit of info from you i need bit of help
keykey
10-01-2023 04:30 PM
TRANSSPORT
04-12-2020 03:06 PM
evilstuie
05-28-2012 10:33 PM
