PE Mode
PE Mode
Can someone decode this for a programming illiterate and explain exactly what has to happen to allow PE mode to happen?
* PWR ENRICH PARAMS
* ANHT TYPE $8D
L85FF: FCB 230 ; 8.1 Kpa VAC to ENABLE PWR ENR
; ARG = 256 - (Kpa * (256/80))
L8600: FCB 10 ; 3.1 Kpa, VAC HYST FOR PWR ENRICH Kpa
; ARG = Kpa * (256/80)
L8601: FCB 16 ; 6.25% TPS HYST, PE off if TPS LT (L8603 - L8601)
L8602: FCB 209 ; USE TBL L8608 IF COOL = or GT (116c), (244F)
; PWR ENRICH TPS THRESHOLD vs RPM
; FOR NORMAL COOLANT
; *** WOT ***
; TBL = TPS% * 2.56
; TPS% RPM
L8603: FCB 128 ; 50 400
FCB 128 ; 50 1200
FCB 128 ; 50 2000
FCB 154 ; 60 3200
FCB 180 ; 70 4800
I'm particularly interested in L85FF & L8600 and how the work together.
I had previously made my car idle in PE mode and now can't make it work again. I had set L8601 to 0 and L8603 & L8604 to 0 and it worked. But that was when my motor idled at @ 30 KPA. Now my motor idles at @ 40 KPA and it doesn't work.
I'm confused by L8600 and how it relates to L85FF. I'm sure this is a map (vacuum) issue. Can anyone help? Thanks.
Regards,
Gary Anderson
* PWR ENRICH PARAMS
* ANHT TYPE $8D
; *** WOT ***
; TBL = TPS% * 2.56
; TPS% RPM
FCB 128 ; 50 1200
FCB 128 ; 50 2000
FCB 154 ; 60 3200
FCB 180 ; 70 4800
Regards,
Gary Anderson
david068513
09-18-2015 10:36 AM
