ed wright custom fastchip & 24# ford inj
Car: 91 pro street camaro
Engine: F1r procharged stroker
Transmission: turbo 400 w/gearvendor OD
Axle/Gears: moser 9" 3.89 35 spline axles
just installed ford 24# injectors & custom fastchip, now it runs like a pig! Was running 45psi and lowered it to thirty five. do I need to change timing? I'm new at this. any tips appreciated!! papasmurf
1 Post
Car: An Ol Buick
Engine: Vsick
Re: ed wright custom fastchip & 24# ford inj
You'll probably have to modify the VE table(s), and timing.
The short pulse width linearity can change enough between brands that you have to adjust the VE table to account for the difference.
Using a scanner will tell you where your at as far as MAP and rpm, then start changing the fuel in those areas that you can watch the BLs to see where you are reference to 14.7.
