Low Octane Knock Retard
Old 08-18-2003 | 07:44 PM
Swapmaster's Avatar
How do you disable the Low Octane Knock Retard Routine in the P730? Just set the retard amount to 0 in the constants table?
Old 08-19-2003 | 08:26 AM
poncho@home's Avatar
Car: 2004 BMW 330Cic
Engine: 3.0
Transmission: 6 speed
Why? Knock is a bad thing. Your ecu is protecting your motor by retarding the timing.
You should either pull back some timing or run higher octane, either way your goal should be to eliminate Knock not the retard.
Just my .02$
Old 08-19-2003 | 11:05 AM
Swapmaster's Avatar
Read this thread
https://www.thirdgen.org/techbb2/sho...highlight=p730
Old 08-19-2003 | 12:27 PM
Engine: 3.0
Ok, I guess...didn't really read it all as it doesn't apply to a MAF 165 system like I am running, but I know of Glenn and I can accept that at face value. But it seems to me that's more of a "bug" in the 730 ECU, not returning total advance spark untill resetting the ECU is not intentional, I presume.
What I understood from your question was that you wanted to disable the knock sensor from actually doing what it's supposed(retard timing if knock is detected), so I responded as I did. Either way I still think your goal should be to eliminate knock!
I have a friend who recently disconnected his knock sensor thinking he'd go faster in the 1/4 mile, ended up losing 3 tenths. I assume the ECU is pulling back timing because there was no signal from the knock sensor? Who knows, but I laughed hard, because we've had this discussion before and he's been trying to get me to disconnect the knock sensor on my car, while my argument has always been, well if I don't have any knock, then my knock sensor won't tell the ECU to pull back any timing...so why should I disconnect it????
Old 08-19-2003 | 12:41 PM
Swapmaster's Avatar
That's cool. I'm just learning this stuff and soaking in as much as I can. Doing constant searches on the 730 ECM on what to do with it is almost a full time job.
Old 08-19-2003 | 12:48 PM
Engine: 3.0
I hear ya...I've been at this for over a year and I still only know a miniscul amount of what I'd like to know.
manualbrakes.com
Brakes
63
04-09-2024 11:55 AM
ericjon262
09-11-2015 06:07 PM
FormulasOnly
09-10-2015 09:07 PM
MSgt Luttrell
09-05-2015 11:28 AM
tgp1990
09-04-2015 06:24 AM
Quick Reply: Low Octane Knock Retard
