DIY-WB o2 question
Car: 92 Camaro RS
Axle/Gears: 3.73 Truetrac
DIY-WB o2 question
Got an echlin o2 sensor for the DIY-WB set up, but I read around that the sensor should say L1H1... Mine says L2H2, same echlin part number I can find everyone elce useing that echlin part number, just wanna know if this is a problem.
1 Post
Car: An Ol Buick
Engine: Vsick
Re: DIY-WB o2 question
The only way I'd sort of trust it would be if I could run it back to back with a L1H1. Short of that, I dunno what you could do. It's the same as the one pictured at the DIY-WB site?.
Car: 92 Camaro RS
looks exactly the same, part # OS791 on the box from napa, was just takein a look closely and saw the numbers were different.
Car: 84 SVO
Engine: Volvo headed 2.3T
Transmission: WCT5
Axle/Gears: 8.8" 3.73
I wonder if someone bought 2 sensors, and returned the OS791 with the cheap sensor in the box.
E-mail I recieved from NGK Rep.
>> >Barry,
>> >As we have mentioned previously, UEGO wideband oxygen sensors are in
>great
>> >demand worldwide.
>> >Here are some facts that you may have interest:
>> >The original 5-wire wideband oxygen was produced for the aftermarket by
>NTK
>> >for the 1992-93 Honda vehicle. The Honda OEM application was their OEM
>part
>> >number 36531-P07-003 marked "L1H1" on the oxygen sensor and sold to
>ECHLIN
>> >under their part number OS791.
>> >The "L1H1" has been upgraded with the output being the same (a few wire
>> >color changes and length updates) to "L2H2".
>> >Honda's OEM part number for this "L2H2" is 36531-RCA-A01. You can go to
>> >Honda dealership and confirm the design to be the same.
>> >The "L2H2" was updated by Honda to the current "L3H3" which carries two
>> >Honda part numbers: 36531-RDJ-A01 and 36531-P2M-A01.
>> >All of the above are interchangeable for the air/fuel data logger Engine
>> >Management Systems.
>> >However, the BOSCH part numbers for their wideband oxygen sensors are not
>> >considered interchangeable with the NTK.
>> >BOSCH produces several of their own 5-wire wideband oxygen sensors:
>17014,
>> >17018, 17033, 17034, 17035, 17036, 17044, 17053, 17085, 17090, 17125,
>17138,
>> >17144, 17146, 17179, 17185.
>> >FYI
>> >Ralph Harris
>> >NGK Spark Plugs (USA), Inc.
>great
>> >demand worldwide.
>NTK
>part
>ECHLIN
>> >Management Systems.
>17014,
>17138,
>> >FYI
>> >Ralph Harris
I to have heard of the L2H2 as I am trying to find an L1H1 for my DIY-WB. I am in AZ and checkerauto, proauto, autozone, bap import, and pepboys are all out of stock and unable to order the Bosch sensor 13246. There is 1 NAPA in AZ that has 1 sensor, the OS791, so I think this is great news. I ask the guy to verify l1h1 on the sensor body and he reports back that it is l2h2. So I drive over to take a look at the unit. Sure enough L2H2 It looks just like the l1h1 but has 2 different colr wires and a heat sleeve around the wires. It was being sold out of the OS791 box.
350$ was the asking price but he said he would give to me for 250$ but was unable to sell it any cheaper then that as he said that was as far as the computer would take it down.
Opinions PLease!!!
Opinions PLease!!!
Options!!!
You guys know I'm with a local NAPA Store. I've got the OS791 L2H2 for $220 + $10 shipping. That will save you $20. Your lucky to even have one that close to you! I don't think many of you will be able to find it at a local store. Napasales@go.com Thanks guys!
Car: 92 Camaro RS
yup yup hes right, im an employee of one too, he he cept i got mine Z'ed, only the napa guy would know what that means. Price is 220$, so i guess i just got a new updated model... cool, that helps relive some pressure.
Car: check
Engine: check
Transmission: check
Originally posted by ZZ28ZZ
I got my sensor, but can't find the PCB. Anyone know where I can find one??
www.diy-wb.org
Should have parts kits too.
A more direct link is:
http://www.diy-wb.com/info.htm
There is even a Digikey part number for the parts required to build the DIY-WB unit. That is cool, one part number gets you all of the parts.
RBob.
Car: 82 Z-28
Engine: 383 TPI
I tried the DIY EFI WB link a few weeks ago. It took me to a page where you fill out a form with name, address, etc. Got what looked like an autoreply msg that said there was a several week delay. Haven't heard anything from them since.
The sensor is the L1H1.
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
Originally posted by RBob
Can order them through the site at:
www.diy-wb.org
RBob.
www.diy-wb.org
RBob.
Bill
I imagine not. Anyone who upholds to the agreement of use at DIY-WB wont sell them either. You might be able to find someone and offer up another service as a trade.
Car: check
Engine: check
Transmission: check
RBob.
1 Post
Car: An Ol Buick
Engine: Vsick
Originally posted by va454ss
Is there anyone on the site that will build the WB unit for a fee?
Bartering, is another matter thou.
As much as it is a neat tool, part of it's purpose is to be educational. If soldering, ain't your thing, might be time to learn, since with working with EFI it's just a matter of time before you need to be able to.
Great pics of both L1H1 and L2H2
Check this out for detailed pics of both the L1H1's that I had and the L2H2's that I have. Same stuff guys. Need one? Write me: NapaSales@go.com
http://www.home.earthlink.net/~barry...gen%20Sensors/
Re: E-mail I recieved from NGK Rep.
>> >Management Systems.
>17014,
>17138,
>> >FYI
>> >Ralph Harris
>> >Management Systems.
>17014,
>17138,
>> >FYI
>> >Ralph Harris
Well I own an L2H2 and am in Phoenix AZ. It will be a few weeks before I get around to building the controler. If anyone in the area has a DIY WB-O2 they can use my L2H2 for testing Vs. the L1H1.
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
I cant find one around here for under $299, and even $220 seems too pricey for my budget. Is it possible to build a WB with a used sensor from a junkyard?
1 Post
Car: An Ol Buick
Engine: Vsick
I was at the junkyard for a spindle last week and just for grins looked at all the Hondas for a WB. No luck at the yard as all the motors in WB equiped civics had already been pulled.
I will be most impressed if you can find one for well under 200$!!!
Actually I will be impressed if you can find one at all for sale by retail outlet for less than 300$
Car: 82 Z-28
Engine: 383 TPI
Primo>> If you do wind up at the junkyard, but can't find a Civic with a wide band o2 connector, the Civics have other connectors under the hood that will plug into a WB o2 sensor. I found 2 near the pass side shock tower. One was missing a wire the O2 sensor needed. The other one I found in the same area had all the wires needed. They were the wrong colors, but no biggie.
Best part was, when I asked the junkyard guy how much, he just shrugged his shoulders and said "take it".
91L98Z28
02-18-2005 12:05 AM
