need cop car chip with vats disabled
Car: 1995
Engine: 5.7
i resently installed an alarm with remote start and i have all the stuff to burn a chip except for a editor. Tunercat seems to be the only one for a 91TBI. and i haven't bought it yet. so does anyone have the cop car chip, i think its ANLU something. i need it with vats disabled. thanks
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
http://gmecmedit.markmansur.com
no reason to buy tunercat. find the ecu that matches your ECM and code mask.
regarding anlu: www.diy-efi.org/gmecm
Car: 1989 Camaro RS
Engine: 355 mildly modified
Transmission: 700R4 fully modified
The chip is acdelco part number 1#16143692. This one is going to still have vats enabled, but if your getting tunercat you can pull that out.
Thats for a 350 caprice cop car tbi.
Hope that helps,
Mike
Hope that helps,
Mike
Car: check
Engine: check
Transmission: check
Originally posted by TKD89RS
what i meant was, does anybody have the bin with the vats disabled. and GCMedit has no ECU for my car.
RBob.
Transmission: T5WC
Meanwhile, you can find your bin in the www.diy-efi.org ftp site. There are about 5 copies of it sitting in there.
Car: check
Engine: check
Transmission: check
Originally posted by Mangus
Ah yes, $61... if you ever end up creating an ECU for it, let me know.
ftp://ftp.diy-efi.org/incoming/8746jonprevost.ecu
RBob.
Transmission: T5WC
Originally posted by RBob
By one of our own thirdgen members:
RBob.
RBob.
Well, there you have it. Now you can use GMECM Edit with this bin. =)
Car: check
Engine: check
Transmission: check
im using the anlu bin right now, and vats is not disabled
I can email you a stock ANLU bin, just PM me with an email addy to send it to.
RBob.
edit: P.S. I posted the ANLU bin to the TBI board a while ago. Just searched and can no longer find it. Anyone have the thread URL?
Car: check
Engine: check
Transmission: check
i checked the bin with winbin and it does have the vats disabled but the frequency is at 255.
In this case just flipping the VATS enable bit w/o changing the freq locations and VATS still won't work properly.
RBob.
Car: 1995
Engine: 5.7
so ur saying just disabling vats wont work, because it was disabled and vats was still working. i just grounded the starter relay to disable it. but i still want to know y my vats was still working even though it was disabled in the chip.
Car: check
Engine: check
Transmission: check
This is because the VATS freq settings in the chip are not set. In order to use ANLU w/a VATS setup, both the VATS enable bit needs to be set along with setting up the proper upper & lower freq boundries in the cal area.
In some of your orignal posts it almost sounded as though in your bin someone enabled the VATS option and did not program the freq calibration. That would create a disabled system as the engine wouldn't start even with a proper VATS signal.
As an FYI the portion of VATS in the chip only stops the injectors from delivering fuel. The starter disable is from elsewhere.
RBob.
Car: 1995
Engine: 5.7
well then i guess i grounded the fuel relay, what ever relay is in the driver side kickpanel, i grounded the black/yellow wire and now i can start the car with no vats.
the chip i was saying has vats disabled under the flag data, and under the constant i think it says the freq is 255. but the vats was still working in my car.
9192camaro
16
02-03-2019 12:21 AM
NBrehm
08-25-2015 11:49 PM
