7747 burst knock retard?
Car: Bee-Bowdy
Engine: blowd tree-fity
Transmission: sebin hunnerd
Axle/Gears: fo-tins
I'm switching over to a 305 soon so naturally I've been looking thru alot of different 305 bins for a good starting point.
I see that most of the 305 bins used the burst knock retard. What is burst knock anyway? I heard once that there is no attack rate...if the ECM sees knock then you get the full 9d retard. Is that correct?
Also, I like the ARPC cal the best. It's for a manual and I have an auto. I'm curious what all has to be changed. So far I've switched: TC/SL switch to 0. Then I set the TC lock-up stuff the same as an old cal I had.
I also turned off the burst knock and turned on the regular knock retard, for lack of a better name.
RedLeader289
05-28-2019 01:47 PM
bigjay89gta
10-15-2015 08:04 AM
efiguy
09-27-2015 01:30 PM
