GM ECM or aftermarket?
How do the GM ECM's compare with thye common aftermarket types in terms of speed, resolution, processing power etc? The common school of thought seems to be that the GM units run rings around almost any aftermarket types but in what way? Why are they better?
Car: too many ...
Well I have limited experience with Gm ECM's, but I think the only aftermarket ECM's that are worth the $$ are the ones for F/I applications. ECM's that can calculate A/F ratio in relation to boost. Speed Pro's F.A.S.T. would be a good example. But even then you can find a cheaper alternative using GM ECM's (749 SyTy ECM for example).
What is basically comes down to is that if you're willing to take the time (blood sweat and tears) to learn the GM stuff then its good enough for anything the weekend warrior can come up with. Those $$ aftermarket ECM's probably are easier to setup and tune, but thats why you're paying the $$.
1 Post
Car: An Ol Buick
Engine: Vsick
Re: GM ECM or aftermarket?
Using the right ecm gives you more then enough resolution. Remember these are designed to keep the EPA, folks happy.
What aftermarket co., has 2% of the resourses GM does for designing their stuff?.
You can afford to carry a spare junkyard GM ECM, how many folks can carry a spare aftermarket one?.
Many of the aftermarkets don't even allow you to run a Converter lockup.
They'll hype themselves to death over non-issues, just to try and sell something.
It's easy to get cheap ECM's with not only >1 bar MAP sensor capacity, but knock control, IAC capacity and closed loop feedback.
However, I'd be interested to know what's the cheapest price for an ECM that has the Delco's Limp home mode (the car will run without the Memcal), can work around sensor loss, has a lean cruise mode, 70 different ways to control idle quality (I may be exaggerating to make a point) and has on-board diagnostics.
John
1 Post
Car: An Ol Buick
Engine: Vsick
Originally posted by Tomcat
Give me a yell , I am in Perth and can get yah started.
Or does he need to throw lots of money while yelling?. LOL
Yeah I agree that if you research it enough, you can get much better results from the Delco product than the aftermarket. Well cheaper too! Boards like this are a HUGE help!
Hey Tomcat - where in Perth are ya?
Originally posted by Grumpy
So your doing DIY?.
So your doing DIY?.
Yes I do now make a living from Dyno Tuning but only from those who cant be bothered putting in the effort to sort it out themselves and from those wanting to hire my dyno to test.
No I dont sell kalmaker but I do use it from time to time as well as working in hex
PerthZ28 I am in Maddington
aftermarket, capability, comparison, ecm, fast, gm, gmc, iac, junkyard, market, pcm, processor, prom, proms, speed
