What happen to Traxion's article on chip burning and >>>
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
I purchased the 8D definition file from CATuner, but have lost the stock SD automatic ECM tables that I had. Computer crashed last Spring and I have not been able to recover everything. I have been fumbling around about switching to SD.
I also lost the link to the ECMGUY site (or whatever it was).
I think that that link was in Traxions article.
Can someone help me out? TIA
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
My article is in the same place it has always been .... in the technical articles of thirdgen.org's site. Here is the direct link:
https://www.thirdgen.org/newdesign/tech/promintro.shtml
If you truly do have a legal copy of the 8D TDF then just e-mail TunerCat for the newest copy.
Tim
Tim
Car: '87 IROCZ
Engine: 395 ZZ4
Tim, I looked in the tech articles and did not see it, I'm having a bad day.
I was not clear about the second (more of my bad day). What I need is a stock .bin file that I can read with the 8D definition file. I remember that I had gone to some site (that I think is in your article) and downloaded two .bin files for 8D.
Tim, thanks for your reply.
Car: '87 IROCZ
Engine: 395 ZZ4
OK, I found the aujp.bin file, and my 8D definition file reads it.
Is this for an automatic or manual,, also is it a 350 or 305?
What I'm looking for is a 350 with an automatic.
OK, got my own answer, its a 350 with an automatic
1 Post
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
1990-02 1227730 ECM, L98 (350ci), MD8 (700r4 automatic)
Street Lethal
09-07-2015 01:09 PM
