Cheapest programmer...
#51
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
Originally posted by novass
Yahoo!! It worked. Tried a third computer and it worked!! I was able to burn the chip the 29c256. It verified fine and I loaded the info from the chip back into the computer fine.
Now all I have to do is put the engine back in the car!
#53
Car: 93 Caprice 9C1
Engine: L05
Transmission: 4L60
2732A
Originally posted by Chuck!
Where did you pick up the Intel 2732A's? Ive been checking on the internet and cant seem to find a place.
The ST 27C1001 and TI 27C128 will work with the 8746, too without any special stuff?
http://www.jameco.com/cgi-bin/ncomme...nbr=501&ctgys=
$3.99 each.
Haven't had a single problem on the programming end or the car ECM end.
#54
Re: 2732A
Originally posted by kevm14
I bought 10 from Jameco.
$3.99 each.
$3.99 each.
#56
My point was, they work flawlessly, and the price isn't bad.
I am using the PP2 with Win98.
#58
Car: 1990 Formula
Transmission: WC T5
Originally posted by GTA91
So what programmer and what windows program did you finally use to get it to work??? Thanks
The two computers that did not work were a compaq laptop 120mhz and a generic 233 mhz desktop.
It ended up working on my 1.4ghz athalon with win 98. I have a dual boot system, most of the time I use xp, however, I have a small partition that is still win 98 just for this type of stuff. I have not yet tried it on the xp side.
#59
spep plus programmer and win 98 OS. I dont know if it had something to do with the speed of the other computers.
#61
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
I'd seen some problems with a ca. 200mHz laptop machine, but it had a BUNCH of stuff running in the background (antivirus, etc). Once all that was turned off, it did fine.
Of course, I have no problems with my XP2200 desktop in Win98. WinXP is still squirrely as heck though on LPT/COM stuff, even with all the port-activation code, etc.
#62
Car: 91 Trans Am Convertible
Engine: 300 HP 350 CI
Axle/Gears: Drums?
I just wanted to confirm what I've read from this post. I can get one of the SPEP Plus programmers, go to radio shack and get a power supply for it, get an adaptor and chips from Craig Moates, download the free programming software, and I will be ready to burn my own chips. Is this going to be everything I need, or is there something I'm missing? I want to make sure I have a handle on everything before I start ordering parts. Thanks for the help.
#63
#64
Originally posted by TORC
No problem... here's what I found:
ST 27C1001: Programmed with Windows software without any problems.
TI 27C128: Programmed with Windows software without any problems.
Intel 2732A: Programmed with Windows software without any problems.
ST 2732A: Failed to program with Windows software, programmed with old DOS version.
TI 2732A: Failed to program with Windows software, programmed with old DOS version.
(Note: some TI 2732A's failed to program with either Windows or DOS)
Mitsubishi 2732: Failed to program with Windows software, failed to program with old DOS version.
NEC 2732: Failed to program with Windows software, failed to program with old DOS version.
TI 2732: Failed to program with Windows software, failed to program with old DOS version.
Thanx,
Ben.
#65
Axle/Gears: Drums?
Does anyone have the exact info for the adapter from radio shack? I didn't know if they use any kind of part number system, but I didn't want to have to try to get some salesman to understand what I was looking for. Thanks
#66
I just picked up a more compact power supply for mine from Wallyworld (Walmart) It's specs are:
Amps: 1000mA
Volts 3-12 VDC
Folding plug blades
6 different switchable plugs
Works great and is quite small for what it is.
Amps: 1000mA
Volts 3-12 VDC
Folding plug blades
#67
Car: 2008.5 Mazdaspeed 3 GT
Engine: 2.3 DISI Turbo
Transmission: 6 speed MT
I just got my power supply this last weekend from Radio Shack. I didn't save the part numbers, but it was easy enough to find what I needed by bringing the programmer in with me. I got one of their better quality power plugs, then spliced on one of the universal adapter harnesses that fit each of the 30 or so ends you can buy there as well. It cost a bit more then the Wally one, but at $25-ish I can power anything I'll ever need by getting more of the plugs.
#69
i just recieved the epromer5 kit last night and had no problems at all with it, just did my first burn and all went well. useing WINXP without a hitch. kit came complete was just a simple plug and play
#70
Car: 2004 BMW 330Cic
Engine: 3.0
I purchased the Willem programmer. It works great. Came complete with programmer, power supply and Windows software that programs a bunuch of eproms. I am using it with ATMEL 29c256 chips and it works perfectly, all this under Win XP
I paid $80 for it.
www.willem.org
I bought it off Ebay but it was brand new...I just did a search for "willem eprom" on Ebay and found 2 for sale...
I give them 2 thumbs up!
I paid $80 for it.
www.willem.org
Damon
09-26-2015 04:29 PM
