15-pin winALDL cable ?
Car: 2002 Z28
im trying to make my winALDL cable but all i have is a 15-pin COM port. The directions only explain using 9 and 25 pin connectors. So my question is, what pins do i use on the 15 pin connector, i cant seem to find anything online. THANKS
Car: 85 Monte Carlo SS...
Engine: T.P.I L98.
Transmission: TH350
Axle/Gears: 3:73 Posi
A 15 pin connector is for a game pad and stuff. I don't think that will work for this application. That is weird that you PC has no com ports. You may have to buy a card that will give you a printer port which is the 25 pin. Or take it to a local computer shop and they could install some com ports for you. What kind of computer is it Mhz wise and stuff?????? I actually made my interface cable last night. Haven't tried it yet, but it's done. Let me know.
Kaz
Kaz
Car: 2002 Z28
I do have a 25 pin LPT port, but i thought i couldnt use that one, i thought it had to be a COM port and not a Printer port. Can I? The laptop is 600MHz.
Engine: T.P.I L98.
Transmission: TH350
That is what the 25 pin connector is. Go for it! Should work, that is if they say you can do it with the 25 pin. I made min eout of a 9 pin com port, so. but I think your able to do it that way... Just can't us a printer at the same time. H=mmm weird, a 600 Mhz lap top without a com port. Yeah just use the printer port, should work.
Car: 2002 Z28
I dont have any 9 pin ports. I also looked at my friends brand new Dell notebook and it didnt have any 9 pin ports either , i guess ill look into the USB adapter. Thanks for the help.
Z28/ZR1
10-23-2015 01:04 PM
TMZIrocZ350
10-07-2015 12:09 PM
