How do you tune in open loop?
What tables does the ecm use in open loop mode. In Tunercat what all can I mess with to adjust my open loop idle at startup. If I change my VE tables will it make a difference or are they only ued in closed loop?
ve values are used in both closed/open loop in most forms of code. foir cold idle there usually a a/f ratio vs coolant temp table. adjusting the ve tables if there not 14.7 with blm int of 128 at normal operating tempature could fix it. otherwise id look at the temp a/f ratio table.
So I should first start with the VE table? In the "Open Loop Change to Fuel/Air Ratio Vs. Coolant Temp." if I make a 1% change is it 1% leaner or richer? Also,what about the "Open Loop Change to Fuel/Air Ratio Vs. MAP." I just would like to get some input on what to mess with first so I am not trying to correct problems in one table when I should be adjusting another. Car seems rich at startup idle then levels out after it goes into closed loop.
car should be rich when in cold idle. if you have zero correctio blm int of 128
Open Loop Change to Fuel/Air Ratio Vs. MAP."these 2 tables will need adjusting. does it idle well if so id sugest leaving it alone unless its pouring raw fuel vapor out the tailpipe. vs map will be above idle and vs coolant temp will affect idle more. both will have an effect on overall fueling when cold.
Then I got a wide band......and then made short work of it! It does take some time as each time it warms up you've got to let it cool again to readjust; but well worth it. I ended up just adjusting the open loop f/a vs coolant temp-seemed like the vs load was fine after first adjusting vs temp where I wanted it.
Blm's were 128+/- before adjusting-had to do minor adjustimng at idle only to get the blms back again after open loop adjustment.
I just don't know what I did before the wide band....
1 Post
Car: An Ol Buick
Engine: Vsick
