Program for stacking bins (for 16k bins on 32k chips, etc)
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
Attached is a little windows app I wrote for stacking bins (that is a little more intuitive and much quicker than the copy /b command line junk).
Let me know if I should modify it to support multible bin stacks (for instance, for Craigs switch that allows 8 bins on one chip).
Its self-explanitory. Give it a try and let me know if I can improve anything!
Mark
Mark
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
Thanks!!! That works slick. I'm just getting into this and this is a big help not having to type in the dos command.
Transmission: T5WC
Good to hear guys.
I fixed some buggs in the append code, so you might want to grab the new version (attached above). This will allow you to copy the same bin on top of itself. In the first version if you tried this the program would not be able to open one of the bins. This is now fixed.
The new version is 0.2
Transmission: T5WC
Originally posted by NEEDforSPEED
i wish it worked for stacking 4kb bins on the 32kb chips
Edit:
Oops, this is a really really old version of Bin Stacker.
Download TunerPro and use the stacker built into it (Open TunerPro, press F5).
http://tunerpro.markmansur.com/
KO1
16
10-15-2015 05:00 PM
