Conversion chart for MAP Volts to Kpa?
Right now all I have to tune with is an Auto X-ray. The MAP is in volts not in Kpa. The Tuner Cat only does adjustments by Kpa. So I am stuck. I need some kind of conversion chart if one exists. Can any one help?
4078, 69camaro454, conversion, convert, converte, converted, converter, converting, convertion, kpa, map, volt, voltage, volts, xray
