how diffrent is 4th gen odb1 prom buring
I have a friend with obd1 lt1 camero. How differant are the parts needed to burn chips for it. Has any body else done this?
thanx
thanx
Car: Death Mobile
Engine: 666 c.i.
Re: how diffrent is 4th gen odb1 prom buring
thanx
thanx
The later 4th gens (8051)s are 'flashed' as there is no Memcal.
Car: 78 Regal
Engine: 82 FBod LG4 305, 730 ECM
Transmission: M20
Axle/Gears: 4.10
Yeah, I have a 730 and a 95 Z28. THe 730 needs all the basic prom burning tools. The 95 Z28 doesn't need the burner. Tunercat has software for flashing the prom that comes in their definition file for the $EE mask. I thought that was a great bargain from them as the other LT1 editor sells for like $500. Imagine, this just cost me an extra $20. Even though I think the other program comes with its own scanner, I use Freescan, so it doesn't even make a dent in the price. Thanks again to Tunercat.
But what cable can I use with tunercats?
Thanks for the timely info!
Car: 78 Regal
Transmission: M20
Axle/Gears: 4.10
Same cable they sell for LT1 edit at AKM cables or build your own. I think he sells a kit for $35 unassembled without the wires but everything for the PC board is included. Better than $100 and quite honestly, do you really need the OBD adapter when you can tap right into the wires?
