MAX232 IC Chip
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 86 IROC
MAX232 IC Chip
I am going to build a aldl interface. Does anyone know where to get this chip? Radio Shack can't get it. Is there another chip I can use beside this one?
Car: 87 T/A
Engine: 441 SBC 12.5:1 0.680" Lift
Axle/Gears: 4.10 TruTrac Moser 9"
Jameco.com is cheaper and has stock of that stuff. Digikey has more variety of stuff though. But for small orders Jameco rules..
You can also try http://www.mouser.com/ ,I've had good luck with them.
If you read the spec sheets on the chip it will explain to you what the different suffixs mean. You're looking for a DIP package chip. Things like temperature range and voltage tolerances are up to you, but dont matter in the operation of the circuit usually (speaking in general terms here.) I *think* in maxim that would be a MAX232ECP, but you need to check in the spec sheet.
Gunner242
12-25-2015 04:49 PM
KO1
16
10-15-2015 05:00 PM
